long block questions
BmOnEy
125
Marietta, GA
i'm looking to buy a 347 stroker and came across this one with these parts.
347 Ford 5.0 Stroker Long Block (NR) Edlebrock Victor Jr Heads - Stage 1's Engine Professionally built by C.H.P Coast High Performance aka Probe Indust. .030 bore w/ torque plates 286/288 duration roller cam (112cntrlne) .565/.582 lift with 1.6 roller rockers 9 to 1 static compression -(motor built for 14-18 lbs of induction) steel girdle support w/ ARP mains H-beam rod at 5.35"(pin away from oil ring Probe top of line forged pistons Victor Racing Gaskets, Head Gasket o-ring. ARP head studs New Factory Roller Block w/ new scat 3.4 stroker crank.
is there anything wrong with this picture and how much should be the most to spend on this setup. thanks for the help.
Brian
