Stock long block with vortech
Kid wita 5oh
I'm definitely not in the original hole
1,406
149
93
Saugus, MA
So blew up my 347, #1main bearing failed and the crank snapped(Scat cast) right in front of the #2 main
I may try to salvage what I can out of it but the stock block after a failure like that has me concerned.
So my plan for the rest of the season is to throw my stock long block(118k miles) in with the vortech(possibly pulley change for less boost)
What valve springs should I use on the E7 heads and will I need hardened push rods too? Most likely staying with stock rockers
Use the heads off of your 347!
I haven't gotten them off yet but, I can almost guarantee there's bent valves... If there are none bent I will ..
But also concerned with the roller rockers having metal contamination in the bearings... No?
But i would definitely need hardened pushrods with those(maybe same length as I have?).... How about stock heads with upgraded springs?
