  • SN95 4.6L Mustang Tech
Long Tube Install
  • Thread starter Thread starter QU!CK
  • Start date Start date Mar 17, 2006
QU!CK
146
Charlotte, NC
Mar 17, 2006
  • Mar 17, 2006
This will be my first time installing LT's and I'm using the article from www.fnsweet.com
Can anyone tell me roughly how long this might take if I use a lift and power tools at a shop?
FWIW, I have flowtech LT's, X-pipe, and Magnaflow Catback to install.
-J
shallowreef
illinois
Mar 17, 2006
  • Mar 17, 2006
My ''guess'' 6-8 hours if you don't hit any major problems.
QU!CK
146
Charlotte, NC
Mar 17, 2006
  • Mar 17, 2006
Wow...that long even if I have a few extra pairs of helping hands?
-J
shallowreef
illinois
Mar 17, 2006
  • Mar 17, 2006
Maybe lees than if you have helping hands. I'm not really sure everybody i've ever talked to says that headers take a long time to install and can be very time consuming.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Mar 17, 2006
  • Mar 17, 2006
Its your first time? prolly all day. Because your double, triple checking what your doing. Plus your not sure who everything is situated there. Getting all header bolt to tighten I think took me the longest. Some bolts with BBK LT is impossible to get to, and you can only turn about1/100 of turn at the time. If you have air tools, may be bit faster with everythng else tho. First time i did(following same article), took me 2 days.
Secondtime, about 6 hurs. 3rd time, 3 hours..
QU!CK
146
Charlotte, NC
Mar 17, 2006
  • Mar 17, 2006
mity2 said:
Its your first time? prolly all day. Because your double, triple checking what your doing. Plus your not sure who everything is situated there. If you have air tools, may be bit faster. First time i did(following same article), took me 2 days.
Ahh...
Well, there will be plenty of people on hand to help. I'm doing the install at a GTO meet and there will be plenty of people on hand that have installed headers before....just not sure how many (if any) of them have installed Mustang LT's before
-J
mity2
Jul 24, 2003
2,872
StateCollege PA
Mar 17, 2006
  • Mar 17, 2006
friend will help. Just that some header bolts takes forever to tighten due to space you have even with K-member off. Htere are couple of holes in frame rail. I had to look through there whenI tighten rear top bolts on mine(those with BBK knows exactly what I'm talking about)
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Mar 17, 2006
  • Mar 17, 2006
Yea im definitely not looking forward to install some LT's down the road
the98stang
2,408
Clovis, CA
Mar 17, 2006
  • Mar 17, 2006
Get a Haynes or Chilton's repair manual....
BaconBits
84
#10
  • Mar 17, 2006
  • #10
Yeah, I've got mine sitting in my living room and every time I look at them it sends a chill down my spine thinking about the install. But the gains are worth it. I'll have them on by the end of the month. Good luck on your install!!!!
stng
182
#11
  • Mar 17, 2006
  • #11
Mity 2 you did it in three hours, that is amazing! It was like a 14 hour day for me, no joke.
01Steeda
732
Baton Rouge, LA
Mar 17, 2006
#12
  • Mar 17, 2006
  • #12
My Mechanic did it in like 6 Months lol. J/K had alot of work done and they went in with the new engine. He dropped the entire K member in under an hour.. might be a good idea if your using a lift and power tools. I think if it would have been a straight header install he coulda done it in under 2 hours.. honest.
mity2
Jul 24, 2003
2,872
StateCollege PA
Mar 17, 2006
#13
  • Mar 17, 2006
  • #13
Well, when you install LT 3 times(Actually 4 Times) in 2 weeks time, you get pretty good at it
Installed LT. Week later, clutch blew apart. take off LT to install new Spec in.4 days later, Took LT off again to take out POS Spec clutch, and install king cobra clutch in. And day after, Take it off yet again to install new header gasket to replace leaky header gasket....
Trust me. U get really good at it
Which reminds me. If your going to install LT, plan to do your clutch at the same time. U'll never know what'll happen after you install LT headers...
jasonh_86
I
May 20, 2005
1,156
Arkansas
Mar 18, 2006
#14
  • Mar 18, 2006
  • #14
Hey mity2, how are the BBK LT's quality-wise and everything?
I know they're supposed to be good, but I just wasn't sure
mity2
Jul 24, 2003
2,872
StateCollege PA
Mar 18, 2006
#15
  • Mar 18, 2006
  • #15
Actually it was excellent. Mine was ceramic coated, and frange was straight, and as much as it looked as it may not clear everything, it did, have plenty of room around steering shaft. Only issue I had was I had to disconnect EGR tube at the intake, and bolt it to the header first, otherwise will not turn without crossthreadding the thread. It was great buy for 350bucks, and i definatelly recommend it to everyone.
Just not their X pipe. Get H
QU!CK
146
Charlotte, NC
Mar 18, 2006
#16
  • Mar 18, 2006
  • #16
Ahh that's the beauty in these headers....I won't have to loosen/uninstall them to do a clutch change
-J
mity2
Jul 24, 2003
2,872
StateCollege PA
Mar 18, 2006
#17
  • Mar 18, 2006
  • #17
-J
Ahhh you locky bastard!!!
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
  • Gulftown980x
  • Jul 29, 2026
squeak93
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
  • dan50
  • Jul 18, 2026
dan50
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
