Shorties:
Advantages - none
Disadvantages - Requires the same effort as long tubes to install for no power gains
Long tubes:
Advantages - Lot's of power gians, better sounding exhaust
Disadvantages - ground clearance.
Shorties:
Advantages - none
Long tubes:
Left a little bit out.
Shorties do sound better (than stock) and allow you to use the stock size midpipe. Unless I'm badly fooled, they don't require you to pull the motor/drop the front suspension to swap them in. Also, they are normally much cheaper than long tubes.
And there are definitely a couple more disadvantages to long tubes, with the install and cost being the biggest ones; they are a HUGE pain to install, and will normally run you upwards of $500 just for the parts. They also often don't allow you to drop the tranny or change the clutch without removing at least one side.
All of that being said, shorties are a complete waste of money unless you are only looking for a marginally better sounding exhaust. Either keep the stock manifolds, or spend $1000 for parts/install for long tubes and get 15 rwhp and a much better sounding car.
What do the factory cast iron manifolds weigh vs shorties? Removing weight up front doesn't have to make power to be a benefit.
And long tubes require buying a new midpipe as well. So just for parts you are looking at long tubes + midpipe vs. shorties and using whatever you already have spent money on.
So shorties save front end weight, money, and don't affect ground clearance or changing the clutch but don't make as much power and are a PITA to install.
Long tubes add perhaps 20-30 rwhp NA and save front end weight but require buying a new mid pipe, add cost to changing clutch, reduce ground clearance, and are a PITA to install.
If it is solely a power mod, go long tubes. It's worth it. If it is an all around performance mod including cornering behavior, go shorties. And IMHO do either when you change the clutch.
I am getting ready to tear into my car. Installing some good ol cheapy Flowtech's. I will take some before and after pics of ground clearance issues and what not. I will be doing a clutch swap and installing a UPR tubular front end while it's tore apart. I will take the headers, bolt them up, and see if I can drop the transmission with them installed and report back.
BBK "tuned length" shorties FTMFL. Worst mod I ever did. Total waste of time and money.
the other issue with long tubes, that is an absolute deal breaker for a lot if us, is they are 100% illegal in California![]()
everything is illegal in california...thank go for alaska!
