  • SN95 4.6L Mustang Tech
Long Tubes
  • Thread starter Thread starter 04Stanger
  • Start date Start date Oct 23, 2005
1 of 2 Next Last
04Stanger
  • Oct 23, 2005
Why is it that you will have a problems with an inspection if you switch to long tubes?
SWRTstang
53
Laredo, TX.
Oct 23, 2005
  • Oct 23, 2005
Your Stang may or may not comply with emissions(smog) regulations.
jasonh_86
I
May 20, 2005
1,156
Arkansas
Oct 23, 2005
  • Oct 23, 2005
sgarlic
3,085
Oct 23, 2005
  • Oct 23, 2005
I believe he meant WHY is it that you won't pass smog.
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Oct 23, 2005
  • Oct 23, 2005
not sure of the exact reason, but im guessing its b/c you're putting out more emissions since you're removing more exhaust from the motor.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Oct 23, 2005
  • Oct 23, 2005
because long tubes requires removing the OEM catalytic converters which is against federal law. technically removing replacing any catalytic converter with a non OEM or CARB approved catalytic converter for your specific application is against federal law. have fun while it lasts guys, word is in the CA smog community, the whole country will be required to use CA smog testing rules and equipment within the next few years.
Word_Life
Banned
Jun 30, 2005
51
East Coast Lyfe
Oct 23, 2005
  • Oct 23, 2005
+1 for mid length headers
ponysarepretty
578
  • Oct 23, 2005
Thats crap, why don'tthey fix up some of the stuff that actually needs to be done rather than target a select group of people. Like have any of them ever seen semi's they are freaking smokestacks. Smog testing is so gay, lucky for my emissions test they jsut plugged into the OBDII... didn't even look at the underside of my car.
helty
some Ukrainian's enjoying a handjob via my credit
Mar 30, 2005
1,461
Baltimore, MD
Oct 23, 2005
  • Oct 23, 2005
a lot of this stuff is all he said she said. im not calling anyone a liar, but there have been several legislative bills that if passed, would have a huge affect on us. for example, PA trying to ban aftermarket exhaust has been going on for years and every year it gets shot down. and the whole tint thing in michigan. now, standardized smog testing for all 50 states isnt targeting performance enthusiasts, but it will have the biggest impact on us, and in reality its not that far fetched. but i think that if if happens, it will be at least 10 years down the road, even though is probably should be sooner.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Oct 23, 2005
#10
  • Oct 23, 2005
  • #10
i think its crap too. however, if you have been to LA you understand why they have the laws. the air there about 10 years ago was literally unsafe to breathe. now its been cleaned up a ton. and no im not an environmentalist, i just like being able to go outside and being able to breath clean air and drink clean water.
helty
Mar 30, 2005
1,461
Baltimore, MD
Oct 23, 2005
#11
  • Oct 23, 2005
  • #11
i know what you were saying, and i agree. i no tree hugging hippie, but i do think we need to take steps to clean up the environment, and do something about global warming. i dont know the ins and outs of it, but i think it will bite the entire world in the ass unless something gets done. its one of those things that we all know about but dont worry enough about, or just think it will go away, or we'll be gone before any real affects are noticed.
V
VividDreams
200
Lebanon County, PA
Oct 24, 2005
#12
  • Oct 24, 2005
  • #12
ponysarepretty said:
....have any of them ever seen semi's they are freaking smokestacks....
believe it or not, diesels are cleaner than gas as far as pollutants in the exhaust are concearned. yeah, they make smoke, but they are "cleaner"
think of it this way, gasoline emissions=water and diesel emisions= distilled water.
distilled water has had all of the minerals taken out. now, diesels do have pollutants, but far less than gasoline
propellerhead
1,541
"but what's with the but shots?"
Oct 24, 2005
#13
  • Oct 24, 2005
  • #13
Here's what I got from other message boards....
Because with long tubes, the cats will be so much farther from the engine block. The cats need the heat to do their job. Without the heat, they don't do much. Hence, you'll fail the smog test.
V
VividDreams
200
Lebanon County, PA
Oct 24, 2005
#14
  • Oct 24, 2005
  • #14
yeah, thats the big thing about LTs. the cats cant "work properly"
jasonh_86
I
May 20, 2005
1,156
Arkansas
Oct 24, 2005
#15
  • Oct 24, 2005
  • #15
ahh.. who needs cats anyways?
I loovee livin in a non-emissions testing state
mrvax
Stay thirsty my friends
SN Moderator: Orlando, Fl.
Oct 24, 2005
#16
  • Oct 24, 2005
  • #16
From everything I've read, this is correct.
jstreet0204
939
Winston Salem, NC
Oct 24, 2005
#17
  • Oct 24, 2005
  • #17
Before my county went to obdii test I never had any problems passing a sniffer test with bbk lt's and catted h-pipe. In fact, I bought it used from the dealer like that. The place I had it inspected ever really does a visual check though.
wilsonc2222
32
texas
Oct 25, 2005
#18
  • Oct 25, 2005
  • #18
i have bbk longtubes
and bbk catted x pipe and i've passed for three years . but here in texas
all they do is hook up to the port(i don't recall the proper name for it) that
a code reader is hooked up to. i was told that as long as you don't have a
code tripped, your car will pass.
V
VividDreams
200
Lebanon County, PA
Oct 25, 2005
#19
  • Oct 25, 2005
  • #19
thats how pa is too, if its '96 or newer(OBD-II) all they do is a diagnostic port check to see if there are any codes, but if youre not thorwin a CEL you wont have a problem. my buddy works for a honda dealer and had to go for his emmissions license. there was a 4 night class and he was relaying to me what he learned:
there is no visual check for OBD-II cars, so if no codes are thrown youre ok(i.e. MIL elims)
V
VividDreams
200
Lebanon County, PA
Oct 25, 2005
#20
  • Oct 25, 2005
  • #20
OBD-I however has a visual
1 of 2 Next Last
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Brakes Front Brake Hardline Routing
  • 93Nifty
  • Sep 11, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
limp
M
2000 mustang fuel feed tube
  • Mali
  • Aug 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 13, 2026
Mali
M
D
Ford AOD Transmission filler tube orings
  • Dagasser
  • Jul 21, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 26, 2026
