MarSaleenMustan said:well i'm glad you didnt take that too personal, I can see where you're coming from now. all of those 13 second times you see is due to driving, plain and simple, you can do a turbo and engine swap and run 14s if you cant get it to the ground wether its a big inch v8 or a turbo 4 cyl you'll get no where, thats why you see all of those supras with 600hp running 12s... as well as plenty of '03-'04 cobras. If you want to get into the 12s on all motor heads, intake and suspension is all i takes, like I said i ran a best of 13.7 with a 1.8 60 on stock h/c/i, and i'm far from being the best driver in the world. Now if you want to go beyond that and since you say you have above average technical ability you can do a junkyard turbo setup, pump gas on stock everything else should yield you about 350rwhp or so. thats good enough for deep 12s high 11s on street trim level with AC and decent driving, if you want to go all out you can turn up the boost, ( i wouldnt take it to more than 450rwhp on the stock block/internals) and run 10s with an Auto and built rear end.
turbomustangs.com is where you want to go if you want to go that route, you can build a nice kit for 2000-2500 with new components. you can make power and run good times with these cars, afterall you dont get to be credited with briging back the modern performance era by being a dog.
Thats where I am screwed. California emissions won't allow for a custom turbo kit. I'd be hit with all kinds of fines if I were to get caught also. Thats my main restriction with the Civic also. Its only running a TD04H-19T.Pretty damn small turbo. Anyways, I think I am going to search for some 3.73's and an E303. I have 1.7:1 roller rockers in the car now though... Do you think I will have clearance issues with the E303? I dont want to disassemble the engine to clay since I JUST replaced the head gaskets.
I had always heard about 5-10hp. That's surprizing
