Well, I'm still in the process of getting this going. I am having a problem with the mid-bass sound. I have to do some more messing around with it. I will give all the details when I figure it out.
If anyone with a '01+ changer can give me some info. The small connector with 6 wires coming out (mid-bass signal). Where does it go exactly? does it run directly into the high pass amp (below radio)? or does it run directly into the harness to the back 2 amps. On the '00's, The mid-bass signal to the rear amps is split out by the high pass amp. If you hook this up the way you think you would, the mid-bass is weak and the highs are overpowering. I need to know where those wires go in a factory '01+ setup.
Thanks
