  • 1994 - 1995 Specific Tech
lookie what i did!!!
  • Thread starter Thread starter mustangt562
  • Start date Start date Dec 8, 2006
First Prev 2 of 2
donjohn
1,757
Irvine - Southern California
Dec 10, 2006
#21
  • Dec 10, 2006
  • #21
Hey, Thanks for turning me onto Ken, he's awesome... he did my 4pt rollbar and I'm going back there in the next few weeks to install my subframes and cats on my x pipe.
I have a thread on the West Coast forums about him.
ProKiller
3,064
15
78
PA
Dec 11, 2006
#22
  • Dec 11, 2006
  • #22
i've been waiting to get one of these for like 2 years now. I want to get a wideband sensor first as tuning is a MAJOR part of using meth. there are a couple guys(i think eades had it on his last combo) on here that have meth kits, but this is the first NA combo i've heard of.
if your looking for a cheaper meth kit, look into AFM's Mr. Freeze. no electric pump, its all run off of vacuum. it's a cheaper kit too. He uses straight wiper fluid where as the snow kit uses a 50/50 meth/water mix.
diablostang
425
Raleigh, NC
Dec 11, 2006
#23
  • Dec 11, 2006
  • #23
You can't run the AFM Mr Freeze on an N/A setup though, only Forced Induction.
I'm seriously thinking of getting one of those AFM Mr F kits.....
94gts
873
Carmel, New York
Dec 11, 2006
#24
  • Dec 11, 2006
  • #24
im not going to bad mouth the stuff buti have some opinions on why i would never run it
1-methanol (itself) burns clear and that scares the crap out of me
2-i never like being at the "limit" of anything in my car. for example, you can run a TON of timing with this kit, but what if something fails? then you are at a huge risk of a boom. i use the same mentality when i sprayed my car. I ran extra fuel pressure and retarded the timing a few degrees. neither was 100% necessary but i would rather have a safety cushion while walking a thin line.
3-they pretty much say it in their site
In theory, at recommended quantities, most of the mixture is evaporated before it hits the combustion chamber
i like to keep non flammable substances out of my engine as often as possible.
4-They call it "an insurance policy." But if thats the only thing that is allowing you to keep your motor from not blowing up, then I call it a "band aid". Its something i personally would never use
mustangt562
226
Long Beach
Dec 12, 2006
#25
  • Dec 12, 2006
  • #25
the flip side to that is that IMHO 50/50 (h20/meth) is far less "dangerous" to your engine than FORCED air, or NITROUS! and with my set up I can dial down my timing back to 10 at will or dial it up. With a BLOWER you have to take the thing out of the car. Plus detonation is less severe with N/A applications than with FORCED applications. As for the safety of it. If you research meth/water injection it was used in fighter planes in world war 2 and has been used for decades. Dont quote me but I even think it is stock in the WRX'S. Its not a "new" science. From another perspective you dialing down your timing and INCREASING FUEL PRESSURE so you can run nitrous sounds like it has "band aid" & "insurance policy" like qualities also.
Meth burns clear? ok well gas just BURNS. Dont get your point
"but what if something fails? then you are at a huge risk of a boom." ok same with a blower, turbo, or nitrous
94gts
873
Carmel, New York
Dec 12, 2006
#26
  • Dec 12, 2006
  • #26
Lowering the timing and upping the fp is not something that can fail. I am setting them at a certain point, and they will remain constant until I change them back. the concept is completely different.
this kit basically allows you to operate at a point (high boost, or timing) thats not a good idea with out it. If i am able to run 20 lbs of boost on my motor with the kit, but only 14 SAFELY without, then i dont want to see what happens if the kit doesnt do its job at 20psi
methanol burns with a clear flame and is almost invisible. hence why i would not want that in my engine bay....
i am well aware of what can happen if something goes wrong with a sprayed or boosted motor. the are many variables that can lead to something going wrong. these include timing, fuel, tune, etc. This kit is just one MORE thing that can go wrong and if it does you may be in some trouble.
ProKiller
3,064
15
78
PA
Dec 13, 2006
#27
  • Dec 13, 2006
  • #27
to each is own...
diablostang, good point since it works of vacuum/boost.
D
DrnkUrOvaltang!
#28
  • Dec 13, 2006
  • #28
I agree. If you want safety, buy a life insurance policy. If you want to race, grab your balls!!!!!
First Prev 2 of 2
J
  • JRC99
  • Apr 19, 2025
JRC99
J
Drive ability Issue
  • 87foxswap
  • Sep 17, 2018
2005 - 2014 S-197 Mustang -General/Talk- Sep 17, 2018
87foxswap
K
Project Ideas (2006 S197)
  • Kitsune187
  • Apr 22, 2019
2005 - 2014 S-197 Mustang -General/Talk- Apr 22, 2019
Kitsune187
K
Excellent Hagerty Article About The "kings Of The Street"
  • FoxMustangLvr
  • Sep 21, 2017
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 21, 2017
NIKwoaC
What It Cost Me To Not Put An Ls In My Fox.
  • CarMichael Angelo
  • Feb 14, 2014
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2014
CarMichael Angelo
