Looking for aftermarket timing tab for 302 Ford
fastgtracer
15
Florida
I am posting this in hopes that someone out there can provide a part number to an aftermarket decent timing pointer for a 302. Balancer is a Trick Flow Track Max Part # TFS-19007 purchased directly from Summit Racing. I called them to purchase a decent timing tab and they could not find one that would work with this Balancer (as it has 3 sets of timing marks, 10 o'clock 11 o'clock , 2 o'clock) , I was referred to the tech line. The only solution from the tech line was to grind down my factory tab so that TDC lands on the top of the tab, this is ridiculous in my opinion. Am I really stuck with a factory timing tab that TDC does not land on the top of the tab? Yes I have found TDC correctly, and no it does not land on the top of the factory tab. If Summit Tech line has no answer then I am hoping that someone has run across this issue and a solution. I am not into spending $50-$75 for something that does not work.
