Looking for harmonic balancer bolts
  • Thread starter Thread starter bgoins
  • Start date Start date Aug 2, 2010
bgoins
130
hampton roads, virginia
Aug 2, 2010
  • Aug 2, 2010
I'm replacing my broken harmonic balancer and in the process I mangled my harmonic balancer bolts, not my crank pulley bolts. Saw some on LMR but they are ARP and about $25 per bolt! I don't need all that. Just some stock replacements. Checked summit but couldn't fine some for any less. Also, headed to the NMRA race in Charlotte next weekend (I'm pumped), should I just try to pick some up at the swap meet? Any ideas and/or part numbers?
CDQICKGT
229
fort hood, tx
Aug 2, 2010
  • Aug 2, 2010
U talking about the 4 that hold the pulley on? If so I got you covered. Let me know.
bgoins
130
Aug 2, 2010
  • Aug 2, 2010
Heck yeah! How do we work it. I've never bought anything on here off someone.
CDQICKGT
229
fort hood, tx
Aug 2, 2010
  • Aug 2, 2010
Pm me your address. You don't owe me anything for them.
bgoins
130
Aug 3, 2010
  • Aug 3, 2010
PM sent
CDQICKGT
229
fort hood, tx
Aug 3, 2010
  • Aug 3, 2010
Pm received, they'll be heading your way asap.
2000xp8
SN Certified Technician
Aug 8, 2003
8,061
1,647
194
NJ
Aug 3, 2010
  • Aug 3, 2010
I think you are a little confused here (or i maybe).
You say you mangled your balancer bolts, not your pulley bolts in the opening post.
Then he asks if you want the pulley bolts, and you accept.
There is only one balancer bolt.
It's expensive because it may only be rated for one time use.
Arp bolts you can use over and over.
Also note that if you have underdrive pulleys, the crank pulley may be so small that it requires different bolts.
CDQICKGT
229
fort hood, tx
Aug 3, 2010
  • Aug 3, 2010
I caught that as well. But i assumed cause he said bolt(s) and not bolt he was needing the 4 bolts that hold the pulley onto the balancer. If you are needing the 1 big balancer bolt let me know before I send the wrong thing.
bgoins
130
Aug 3, 2010
  • Aug 3, 2010
Sorry for the confusion. I need the 4 bolts that hold my stock crank pulley onto my balancer. I do not have any underdrive pulleys. And those things are pricey. Even like the Mr Gasket bolts (for the crank pulley) are about $15 per bolt. On the other hand I saw a Ford crank bolt (that goes into the crank snout) are only $10 per bolt on LMR.
2000xp8
Aug 8, 2003
8,061
1,647
194
NJ
Aug 3, 2010
#10
  • Aug 3, 2010
  • #10
If it were me, i'd take one to the hardware store.
Match it up, and get a grade 8 version.
Underdrive pulleys usually come with new bolts (allen heads for clearance reasons), and i doubt they are any better than grade 8.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 14, 2025
  • dan50
  • Jul 18, 2026
dan50
