Looking for performance Help
  • Thread starter Thread starter Chris H
  • Start date Start date Dec 28, 2005
C
Chris H
50
Crofton, MD
Dec 28, 2005
  • Dec 28, 2005
Hey all
I just purchased a 1966 mustang with a 289 Stock heads, 270H Comp cam (new valves etc..) K-code headers , electronic ignition, 40 series flowmasters. Mustang II front discs. Brand spanking new front suspension with new 5 leafs in the rear. also, new power boosted brake kit.
To my question, the stang has a rebuilt C4 with a rebuilt 8" peg leg 3.00 rear. I would like to change it to a posi unit and lower gears. I was thinking 3.55 or 3.73. I know this has been a question that has been asked many times but I want to get the right gear to match the 270H cam. My drving style changes from crusing at times to nailing it off the line against my buddies 69 camaro. So if you could help me decide what gear and where I should purchase the posi-gear unit from? Thanks all
-Chris
rbohm
6,698
550
204
tucson,az
Dec 28, 2005
  • Dec 28, 2005
3.50 would be a good all around gear. i would get a power trax from a place like national drivetrain. also look into getting a set of world products windsor jr heads, as bolting on a set nets you around 40hp. especially with your current combo.
steel1212
1,180
Frankfort, Ky
Dec 28, 2005
  • Dec 28, 2005
yeah, your getting nothing from that cam with stock heads. I have ported heads on mine with a 280H cam but really need afr185s or something for that cam and my air gap intake to really perform. Alson on the gearing if you have a c4 your 3rd gear is 1:1 and anything above 3.50s and your going to be cruising at a high rpm.
go to www.randysringandpinion.com and click on the calculators and use the rpm calculator and see what you would cruising at. Another alternative would be to switch to a t-5 or aod.
LMan
1,246
Mom's basement
Dec 28, 2005
  • Dec 28, 2005
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
J
Low RPM jerking
  • Justinkins
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 11, 2026
fasterthangas
F
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
