Looking for some drawing and pics and a couple last questions
BlackBaer5.0
100
I am all done with the motor install ..everything is hooked up and ready to go, just a couple last questions..
1. (oil level sensor) I am not using the oil level sender with my new oil pan. Should I cut the sensor off or tie it back. will the low oil level light always be on (if so how can I prevent it) ?
2. (vacuum) Does anyone have a PIC of the hard line vacuum harness that services the egr/canister purge/air pump.. I saw a pic on here a couple weeks ago, I coldnt find it again.
3. (o2 sensor) Is there a recommened brand of o2 sensor I should use.
4 . (distributor) There was a black and white drawing of how the distrbutor lines up andhow the plug wires should be routed ..It was floating around and I can find it..
5. (91-93 Cobra intake) I know that an egr is supposed to have coolant run thru it to cool it, but why does the cobra intake not have this designed into it..
-geoff
1. i would unplug it and ziptie the plug to the harness somewhere. i think its in the o2 harness? i think i actually took my wires out of the plug lol
3. ford or bosch are good, but doesnt really matter if its new
5. the intakes use an egr spacer and the coolant runs through that
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
