lamrith
If you are in WA then you are not due for emissions till NEXT year anyways, so this year you would not get a notice...
lamrith said:Depending on the vehicle and set-up a non Cat car MIGHT pass though it woudl be a stretch.
it only cost $15 for the deq thing. but also keep in mind that if you dont pass they will refund youre $15 on the spot and you can keep doing this till you do pass. so if you fail youre not out $15 everytime you go. peaceN20Jnky said:Lamrith:
I passed the sniffer with with N20Jnky and no cats without much problem... The first time I was sniffed I failed, so I set the timing way back, ran the tank down to 1/8 and then added 6 bottles of Heat... Passed with excellent numbers... I also kept the car running the entire time to make sure that the O2 sensors were well heated...
I would definately try a couple months in advance... It only cost you $20 bucks and if you pass your done, if not you can try a couple modifications and then if you fail you can put the cats back on the car....
hicalibrbulit said:Luck has nothing to do with it. Some counties/cities do not require deq tests. Anything close to major cities and bend over for the sniffer! My uncle used to register his cars in skagit co so he wouldn't have to test his cars.
SMOKEDYA said:it only cost $15 for the deq thing. but also keep in mind that if you dont pass they will refund youre $15 on the spot and you can keep doing this till you do pass. so if you fail youre not out $15 everytime you go. peace
john
P_T_Bishop said:So does anyone know why my 83 ranger didn't need to go into emissions? It's a 21 year old diesel, does that count for anything?
Cap fails, they make you buy a new one !I don't think so. In spokane, they take your 15 bucks and if you fail, the next one, and only the next one is free. All your test after the 2nd are 15 bucks every time.SMOKEDYA said:it only cost $15 for the deq thing. but also keep in mind that if you dont pass they will refund youre $15 on the spot and you can keep doing this till you do pass. so if you fail youre not out $15 everytime you go. peace
john
