  • 1994 - 1995 Specific Tech
loose axles
  • Thread starter Thread starter Mustangless
  • Start date Start date Jan 25, 2006
Mustangless
903
home
Jan 25, 2006
  • Jan 25, 2006
I have new forged superior axles, new carrier, new gears. The splines of the axles are loose in the axle gear. They are not worn down, just loose. You can turn the wheel back and forth and the ring and pinion does not move, but the wheel does. It sounds horrible when taking off.
Does anyone else have this problem?
9
94fiveptslow
46
  • Jan 25, 2006
bump!!....im curious if anyone has any input on this also....
9
94fiveptslow
46
  • Jan 26, 2006
no one knows enough about rearends to comment??
HGFireHazard
460
Michigan
Jan 26, 2006
  • Jan 26, 2006
I have not a clue, but am curious because I plan to swap out my rear end and axles here in the future. Free bump.
donjohn
1,757
Irvine - Southern California
Jan 26, 2006
  • Jan 26, 2006
I have that problem too... i thought 'riored' or 'rio something' was talking about wheel bearings a long time ago.
but if it's the axles that are moving, wouldn't that be the c-clips? which hold them in (at least that's what I think holds them in)
9
94fiveptslow
46
  • Jan 29, 2006
the c-clips hold them in but that wouldnt affect the rotation of them....i had the rearend appart several times and i think the axles are just lemons to be honest...it happens...one of them is also 1/8 of an inch longer so i had to shim it out so it wouldnt rub the caliper anymore....
On another note..i just got back from the track launching at 5k rpm and nothing broke so...whatever....if it breaks atleast ill know whats wrong...expensive way but seems like the only way right now
9
94fiveptslow
46
  • Jan 29, 2006
oh and the problem is with my car..my friend just posted it up cause i never get on here...so you wont get confused....
95cobraguy
637
11
Concord, NC by way of LI, NY
Jan 29, 2006
  • Jan 29, 2006
so basically your saying that the splines dont really sit properly? maybe the axles are too thin. did that diff specify a special axle to use?
donjohn
1,757
Jan 30, 2006
  • Jan 30, 2006
ooo, i thought you meant that the axles moved in and out some... not rotated some
9
94fiveptslow
46
#10
  • Jan 31, 2006
  • #10
yeah...its forward to back slack....and the auburn pro is a 31 spine diff.....its even the "big spline" option so i dont know what the prob is..im just gonna lauch it until it breaks for now....gotta a s/c and tranny to work on for now...
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Which SN95 axles for 93 LX, disc brakes, ABS rings?
  • dan50
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 3, 2026
7-UP BILL
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
