I hope my situation may help someone else out.
anyway, I replaced my Plugs in March 08, I used the Anti-Seize and torqued the plugs at 25 ft/lbs. about three months later I started to hear a popping from my exhaust, I thought it was just getting hot due to summer and the Long Tube headers would do that. over time the popping got worse and I even had a Dyno tune done but still it was popping. I started to smell gas while driving and thought the fuel tang vapor exchanger was bad, but nope. then last week the popping started when I would get on the gas so I decided to pll the plugs and to my amaisment allthe plugs were loose, three were so loose that I did not even need the wrench to lossen them.
I pulled them all and two of the tip was melted to a nub.
I am replacing all the plugs today, Could I have dammaged the valves since the cylinder was sucking air around the plug making it lean? and Idea or suggestions? what should I look for..
Thanks
Thanks
I know Marc didn't use anti seize when he put the new ones in after the cam swap. I've been putting off even checking mine. If I have no problems, I'll probably wait until sometime early next year and change them when I do the cam/header install.
