Lose weight with AFCO at Brothers Performance!
Afco Perfect Fit K-members not only save weight, they give you the option to run tubular A-arms, or factory A-arms! This K-member also accepts the factory steering rack, and bolts-on at home with no special tools needed!
Afco Perfect Fit K-Members retain factory geometry, wheel base & track width. This K-member sheds 27 lbs. from your front end and 42 lbs. when used with AFCO lower control arms!
Order today and save weight!
