After up to normal temp should coolant be draining into the overflow? i pulled the little hose at the rad and it was a constant flow, and when i increased the rpm's the more came out and after a short drive the overflow bottle was full. shouldnt the cap only release coolant after 14-18lb of pressure, from what i saw it was constant flow i checked rad with no seepage seen.
