  • 1994 - 1995 Specific Tech
Lost Lug Key...HELP!
  • Thread starter Thread starter 94GTLaserRC
  • Start date Start date Mar 10, 2004
1 of 2 Next Last
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Mar 10, 2004
  • Mar 10, 2004
I think I may have lost my lug key. What do you do when something like this happens?? Just wanna know now before I get a flat tire.
Thanks
RC
F
flewthecoupe
  • Mar 10, 2004
Find a 12 point craftsman socket smaller than the lug and a hammer. Keep in mind you'll need a breaker bar, as well.
GTPhreak
5,505
Rowlett, TEXAS
Mar 10, 2004
  • Mar 10, 2004
the ford locks on these cars have the "key" on the inside and the outside surface is smooth. I dont think the socket trick will work in this case
huskerpower02
770
KS
Mar 10, 2004
  • Mar 10, 2004
I had my key break when i was chaning my tires. I used the breaker bar method and that worked great So i had to take it to a tire shop and they air impacted the lug with the lock on it off of the wheel. Thats all the help i can be..
-Drew
94GTLaserRC
11,178
Mar 10, 2004
  • Mar 10, 2004
I have my own impact hammer good to 260 ft/lbs...Can I just hammer on the lug and use that?
Thanks
RC
F
flewthecoupe
  • Mar 10, 2004
On my '93 I just hammered, I mean hammered cuz it is a very tight fit, the 12 point on and spun the lug nut loose with my breaker bar. Takes some doing to get the socket off. The 12 points inside the socket will actually form little grooves in the smooth surface and will allow it to grip the lug nut.
huskerpower02
770
KS
Mar 10, 2004
  • Mar 10, 2004
Thanks
RC
Hammer away RC. That S.O.B is coming off.
-Drew
BBrinks
519
Woodridge, IL
Mar 10, 2004
  • Mar 10, 2004
Are you talking about the key for the locking lug nuts? I thought you could just go to Ford or NAPA and get one that matches the locking lug nut.
VIPERn94Five-0
3,352
Poughkeepsie, NY
Mar 10, 2004
  • Mar 10, 2004
yeah give a tire shop a try...they usually have some various keys lying around the shop....if not give it a try with your impact gun.....hammer away and crank on it....give a breaker bar a try too.....if all else fails go back to the tire shop and they will get it off.....
Anthony
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Mar 10, 2004
#10
  • Mar 10, 2004
  • #10
Don't just start banging away. Put some masking tape on the lip and all around. Socket or something falls it may chip the chrome.
94GTLaserRC
11,178
Mar 10, 2004
#11
  • Mar 10, 2004
  • #11
When you guys refer to a "12-point" socket. Is there a special size to get, or is there only one?
RC
SuperSync
241
Asheville, NC
Mar 10, 2004
#12
  • Mar 10, 2004
  • #12
12-point just means it has 12 "facets" or points that contact the bolt in question. You will need to find one that is just ever-so-slightly smaller than the diameter of the lug lock.
They make 6, 8, 12-point and maybe other sockets, for example, my Craftsman 500+ peice set has most sizes up to 32MM or 1 1/4" in 6/8/12-point. You get better contact on a bolt with a 12-point than a 6, right?
SS
94GTLaserRC
11,178
Mar 10, 2004
#13
  • Mar 10, 2004
  • #13
Thanks SS...but that means I gottta try different sizes??
RC
huskerpower02
770
KS
Mar 10, 2004
#14
  • Mar 10, 2004
  • #14
RC
yeah, very time consuming...just hope you get lucky and find the right one. better yet, just hope you have one that fits.
Numbles
998
Chicago, IL
Mar 10, 2004
#15
  • Mar 10, 2004
  • #15
My budie dave just broke my key when we were gonna put the bullits on. His friends ben came over and hammered the key back into shape and it worked fine. Or just go to a shop. They can do it no problem. Just dont pay over $15 if you can.
95YellowGTbeasT
605
South Carolina
Mar 10, 2004
#16
  • Mar 10, 2004
  • #16
Whenever i got my gears installed i forgot to give them the lock nut and they used a chisel to get the lock nut off with... go figer...
R
rockin_rick
968
Mar 10, 2004
#17
  • Mar 10, 2004
  • #17
If you know the code, you can order a new key from McGard. If not, Ford has a master set that MAY contain the right key. I'd give that a try first. May save some headaches of pounding and chisiling.
Rick
F
flewthecoupe
#18
  • Mar 10, 2004
  • #18
The only master sets I've seen are 6 different sized sockets, smooth bored, and tapered. Haven't seen anything different, would imagine the a master set would contain way to many sockets for all the different combinations that it wouldn't be worth it. The just hammer/wedge the socket on, only difference is it doesn't mar the exterior of the lug nut. I have heard that you can make a template of the lug nut and send it to McGard if you don't know what the specific code is and they'll get you a new key.
2L8ULUZ2
Will kiss Moderator ass for title
3,033
14
99
WNC
Mar 10, 2004
#19
  • Mar 10, 2004
  • #19
Thanks
RC
If it's a factory lock nut then the dealer has the key for them or can order you a new one. Tire shops also have keys for them most of the time as well since many people also loose their's as well and when it comes time for a tire change the shop has to use something to get them off. A good shop will have the tools and the others will just use the big red hammer.
larrendeuce
649
Southern NJ
Mar 10, 2004
#20
  • Mar 10, 2004
  • #20
You could take a grinder with a cut off wheel and made a slot in the lug nut. Then there is a special socket thats used for struts, it looks like a socket with a flat blade on it. Try and make it fit the slot.
1 of 2 Next Last
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 4, 2026
manicmechanic007
01 GT DRIVERS SIDE DOOR LOCK CYLINDER LINKAGE
  • Scwhitten
  • May 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 19, 2026
melo.timo
M
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
