Lost Lug Key...HELP!
I had my key break when i was chaning my tires. I used the breaker bar method and that worked great :rolleyes: :bang: So i had to take it to a tire shop and they air impacted the lug with the lock on it off of the wheel. Thats all the help i can be..
-Drew
On my '93 I just hammered, I mean hammered cuz it is a very tight fit, the 12 point on and spun the lug nut loose with my breaker bar. Takes some doing to get the socket off. The 12 points inside the socket will actually form little grooves in the smooth surface and will allow it to grip the lug nut.
yeah give a tire shop a try...they usually have some various keys lying around the shop....if not give it a try with your impact gun.....hammer away and crank on it....give a breaker bar a try too.....if all else fails go back to the tire shop and they will get it off.....
Anthony
12-point just means it has 12 "facets" or points that contact the bolt in question. You will need to find one that is just ever-so-slightly smaller than the diameter of the lug lock.
They make 6, 8, 12-point and maybe other sockets, for example, my Craftsman 500+ peice set has most sizes up to 32MM or 1 1/4" in 6/8/12-point. You get better contact on a bolt with a 12-point than a 6, right?
SS
My budie dave just broke my key when we were gonna put the bullits on. His friends ben came over and hammered the key back into shape and it worked fine. Or just go to a shop. They can do it no problem. Just dont pay over $15 if you can.
If you know the code, you can order a new key from McGard. If not, Ford has a master set that MAY contain the right key. I'd give that a try first. May save some headaches of pounding and chisiling.
Rick
The only master sets I've seen are 6 different sized sockets, smooth bored, and tapered. Haven't seen anything different, would imagine the a master set would contain way to many sockets for all the different combinations that it wouldn't be worth it. The just hammer/wedge the socket on, only difference is it doesn't mar the exterior of the lug nut. I have heard that you can make a template of the lug nut and send it to McGard if you don't know what the specific code is and they'll get you a new key.
94GTLaserRC said:
I think I may have lost my lug key. What do you do when something like this happens?? Just wanna know now before I get a flat tire.
Thanks
RC
If it's a factory lock nut then the dealer has the key for them or can order you a new one. Tire shops also have keys for them most of the time as well since many people also loose their's as well and when it comes time for a tire change the shop has to use something to get them off. A good shop will have the tools and the others will just use the big red hammer.
