LOST: OE remote entry fob and keys?
slytherin
702
northeast ohio
Oops posted this over in 5.0talk accidentally. I was wonder if you guys know of any other places to get the remote entry fob's other than the dealerships, the keys are the easy part since I have a non OE extra set. For those wondering I think I had a gone in sixty scene my dog either eat them or burried them in the back yard :nonono:
Here's the procedure from the shop manual;
"Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located in left rear quarter panel area. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will lock then unlock to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). The door locks will lock then unlock to confirm programming. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode."
The connector they're talking about is in the trunk on the left side, sticking out of a wire bundle. You have to move some of the trim panelling to see it.
You should also roll your driver's window prior to starting the programming procedure so you don't accidentally lock your keys in the car.
http://www.v8sho.com/SHO/Remote Keyless Entry TSB 97-24-13.htm
Cheers
