Lost power, need help
  • Thread starter Thread starter Flavadave4
  • Start date Start date Sep 18, 2006
First Prev 2 of 2
gcwh02
515
pottstown, PA
Sep 20, 2006
#21
  • Sep 20, 2006
  • #21
i would get either a portable or permanent FP gauge and see what its reading. Keep us updated
Flavadave4
1,044
21
49
Utica, NY
Sep 20, 2006
#22
  • Sep 20, 2006
  • #22
JChalfan said:
He's saying it doesn't matter if the distributor was put in 1 tooth off. You could turn it enough to make up for being one tooth off. If your timing light says you're at 20*, you're at 20* whether or not the dizzy's a tooth off.
Of course make sure you aren't using an adjustable timing light, thinking it's a regular one.
Jeff
So if I am a tooth off it could be acting as though the timing were slightly retarded, even though i have advanced the dizzy 20*?
Tomarrow my adjustable fuel pressure regulator will be here with gauge so it should tell us if the FP is or is not the problem.
Wouldn't it be nice to put it on there and see it low, turn the screw and everything be back to good
P
postalbunny
118
Sep 23, 2006
#23
  • Sep 23, 2006
  • #23
If you see the timing marking pointing at 20° on the balancer when the light flashes then you are at 20° no matter where your dizzy is stabbed.
The light flashes when the #1 plug has juice on it, and shows you where the #1 piston is in relation to the balancer... doesn't matter where the dizzy is stabbed, that only effects how much timing you can add/subtract by moving the dizzy.
D
Daggar
3,902
#24
  • Sep 23, 2006
  • #24
My thought is that you need to go back and readjust the pre-load on your rockers now that things have had a chance to settle in.
You may be a hair too tight and preventing the valves from fully seating.
04sleeper
2,674
14
89
Dallas, TX
Sep 23, 2006
#25
  • Sep 23, 2006
  • #25
He got it running right Dag.
http://forums.stangnet.com/showthread.php?t=661826
Flavadave4
1,044
21
49
Utica, NY
Sep 23, 2006
#26
  • Sep 23, 2006
  • #26
thanks sleeper
First Prev 2 of 2
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
J
MEED HELP!! 86 mustang
  • Jacob0121
  • Jan 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
CAMTWO1070
