loud noise from my fan
rudy herrera
110
:shrug:i have a 5.0 mustang that a recently purchaced
everything looks good
the only problem is this anoying loud noise that comes from my fan it sounds like a old disel truck could this mean that my fan clutch is stuck or something?
help please its realy anoying
Get a cat back exhaust. Problem solved, you hear the exhaust instead of the fan :shrug:
Or you could go with an electric fan setup also, do a search on here and you will find multiple threads on electric fans, and jrich has a great write up that will answer any questions you may have to ask about it
grab the fan right by the water pump. It it moves up and down then your water pump is going bad quick. If not then the fan clutch is getting ready to go out. An easy mod is a dual electric fan setup from a v6 contour or an electric from a Lincoln Mark VIII. I got the duals from a contour on my 86 and I have no more cooling issues:flag:
