  • 1994 - 1995 Specific Tech
Loud Rapid Thud
  • Thread starter Thread starter Aye_plus
  • Start date Start date Feb 2, 2015
First Prev 2 of 2
Foxslider
im not that much of a idiot
Oct 25, 2019
543
156
53
Houston, TX
Jun 12, 2020
#21
  • Jun 12, 2020
  • #21
Ok, thats not it. Little bit of play no problem. I got a ton of play in my diff. I do get a clunk backing out of my driveway. Havent pinpointed it. My car makes unsatisfactory noises, very bad noises. If it aint broke, i aint worred about it. If it's broke, i aint worried about it neither. Lol. God forbid i hit a pothole, its like i just jumped it 30ft.
Reactions: Aye_plus
Aye_plus
46
#22
  • Jun 13, 2020
  • #22
The pothole is the mustangs natural predator.
I’ll try to get a better video.
Foxslider
Oct 25, 2019
543
156
53
Houston, TX
Jun 13, 2020
#23
  • Jun 13, 2020
  • #23
Its either your differential or gears are loose or the trans tailshaft (forgot proper name i think) transmission shaft that driveshaft slides over. IF it only happens while accelerating. Has to be one of those.
Aye_plus
46
#24
  • Jun 14, 2020
  • #24
Well, running with no tires and rotors I got the same vibration. It kinda sounded like it was coming from the gears but also from the rear u-joint. I’m gonna start with the joints before I get the diff rebuilt. Also, the pass side axle moved in and out when accelerating. Not too much but, just enough to notice when you look real close. Is that normal?
General karthief
20+ Year Stangneter
Aug 25, 2016
27,892
10,550
203
polk county florida
Jun 14, 2020
#25
  • Jun 14, 2020
  • #25
Take the driveshaft and have u joints checked and the shaft balanced. It's not expensive.
There is a very small amount of in/out movement to the axle but you should not be able to see it.
Reactions: Foxslider
Aye_plus
46
#26
  • Jun 14, 2020
  • #26
I had the DS balanced a couple years ago then the car sat for a year. I took it to another shop a month ago said that it looked fine. I guess the play Im seeing comes from the tip of the axle. I’m seeing it move probably because I have my face under the fender well while the car is at 4K rpm. I also checked fluid level in the diff and it started seeping out so I guess it’s ok.
First Prev 2 of 2
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jun 28, 2026
joeybuddy96
J
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 29, 2026
ejscarfo
E
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
H
Hanging idle issues
  • HydraX
  • Mar 22, 2025
  • SVT Tech Forum
SVT Tech Forum Aug 4, 2025
squeak93
  • D Durden
  • Oct 20, 2025
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Feb 4, 2026
nickyb
