- May 6, 2004
- 32
- 0
- 0
What should I be concentrating the most on to be able to get low 13's in an 03 N/A GT? If I decide to supercharge later, what should I do/not do so I am not buying parts again? Thanks in advance for the help
, and I don't have any good suspension mods yet. I think gears, a tune, suspension and tires would get you there. And practice (which I need more of)!
2000 Gt, black, weld pro-stars, O-R/H, 2-chamber flows, steeda tri-ax, C&L plenum, Accufab 75mm. throttle-body, 4.30's, alum D/S, SCT tuned
Best 1/4 [email protected]
GTMomma02 said:I'd be there if I can figure out the stupid drag radials, and I don't have any good suspension mods yet. I think gears, a tune, suspension and tires would get you there. And practice (which I need more of)!
I'm running the BFG drag radials on the rear with my stock tires up front. My best time on street tires was a 13.55 with a 2.00 60', and my best with the BFG's is 13.51 with a 1.98 60'.c2see21 said:out of curiousity, what dr's do you have?
I have nitto drags & absolutely friggin hate them. i just can't get a feel for launching on them.
I think my biggest issue is the burnout. I either don't do a long enough one, or I'm sitting too much in the water box. its cause you dont have a stall yet mommaGTMomma02 said:I'm running the BFG drag radials on the rear with my stock tires up front. My best time on street tires was a 13.55 with a 2.00 60', and my best with the BFG's is 13.51 with a 1.98 60'.I think my biggest issue is the burnout. I either don't do a long enough one, or I'm sitting too much in the water box.
Plus, getting to a track this season has been a total PITA, so I haven't gotten much practice time.
c2see21 said:I have nitto drags & absolutely friggin hate them. i just can't get a feel for launching on them. so far my best 60ft with them has been 2.05. heck, i got a 1.9 on street tires (hankook ventus sport k104's). they hook good on the street, but that's as far as it goes
That Sucks! Not you ,but the tires. GT JAY said:Get rid of the Nittosand get some BFG's or M/T Dr's
2.05 60' on Nitto DR'sThat Sucks! Not you ,but the tires.
I've pulled a coulpe 1.9's and Lot's of 2.0's on the stock $hitty GoodYears in mine.
I'll be running M/T DR's come Spring time!![]()
c2see21 said:yeah, man i've tried absolutely every combination of ideas trying to get the stoopid things to hook. from short burnouts, cleaning the tires off, burning 15 layers off, high air pressure, low air pressure...... everything. just wont hook![]()
Wayne S said:I can Cut 1.8s with nittos at 17psi with stock gears even
trust me it's not the driver
i had other people drive it, that could drive as well, just to make sure
