Hello,
i have an 88 GT vert (not that it matters). i have SPDT relays on low beams, high beams, and fogs.
i am wondering if i can wire the low beams to stay on when the high beams are on (like happens if you hold the multi-function switch in "flash to pass" position).
i am wondering the easiest way to do it and if there is a chance of overloading anything (dont think so with the relays). i also wonder if the stock headlight lenses can handle the heat from low and high beams being on at the same time (w/o melting or disfiguring). i have stock output bulbs in there.
i wanted to ask the wiring wizards about the way to do it. i was thinking that if i run a jumper from the high beam relay output (N.C - terminal 87) to the positive input coil terminal (86) on the low beam's relay, if that would not have a latching effect on the low beam relay. i dont think so......
or is there a way to tap into the flash to pass position and activate that when i want lows and highs on all at once (w/o holding the stalk back)?
please share any ideas about this idea. what is the simplest way to do it? also mention ancillary stuff like blocking diodes if it is necessary.
many thank to any and all advice and ideas.
