Low compression on 2-3 plugs?
semperfi510
249
Fremont, CA
I did a compression and had low readings on 2-3 plugs on the passenger side heads. What could it be cracked rings, head gasket or any other ideas? I am doing a leak down soon just trying to get ideas. It is on my boosted Saleen. Thanks for the info.
JOhnny :flag:
bdcardinal said:
are those the numbers from the leak down or the compression test. if you are only getting 35psi on a compression test than there are SERIOUS problems with your motor.
i think it was 35-45 from the compression test on either 2 or 3. I have had others say they had similar during a compression when the head gasket blew. I have no knocking on my engine though and it still runs ok except for the blow by?
Johnny
Johnny
unfortunatly your not going to be 100% sure untill tear down, but I agree it sounds like a head gasket.
