I have long deck 302 block, and I need to gain some compression to wake up this engine. Wondering about milling those .030". Wondering how far is it possible to go? Can I have piston at TDC above the block let's say 0.01" with regular gasket 0.04" thick?
The engine has some 8.78:1 (218/228 cam) making only 130 cranking psi.
What pressures are safe to use pump gas with cast iron heads?
I would like to avoid replacing pistons due to their cost. What I see on every corner are expensive performance forged pistons prized $500+ while regular cast dish pistons cost 80-100 US/set. Yet are there any OE domed pistons fitting sbf? Looking for -6cc maybe -8cc.
