Low Coolant Light
  • Thread starter Thread starter savegoodautonfg
  • Start date Start date Dec 8, 2006
savegoodautonfg
1,085
  • Dec 8, 2006
My low coolant light stays on all the time since about a month ago I dont understand why. My coolant level is fine, and plus my car never overheats..
Any ideas?
stangjunkie
381
  • Dec 8, 2006
they are famous for going bad you can pick up a new one or ignore it or close the circuit manually so the light goes off...
bill302
2,131
alabama,gadsden
Dec 8, 2006
  • Dec 8, 2006
pull the sensor out of the overflow bottle and at the bottom of the sensor their is 2 metal tabs at the bottom of the sensor clean them with a metal brush that should fix your problem the metal tabs corrode over time which will cause them to work improperly...post results..
G
GTOreturns
Well-Known Member
Oct 1, 2003
51
17
59
West Coast Best Coast
Dec 8, 2006
  • Dec 8, 2006
If your overflow tank is low that is what its going by. Is the overflow tank low?
bubba-dough
1,044
Indiana
Dec 8, 2006
  • Dec 8, 2006
All of the above....Junk sensors known for going bad. Actually having low coolant in the overflow. Clean the prongs on it. Unhook the sensor but remember to check coolant level routinely, as well as if you get rid of the car let the next owner know.
savegoodautonfg
1,085
  • Dec 8, 2006
i'D RATHER just replace whatever you guys are talking about.
What is the thing called I need to replace so i can tell my dad to get it at the store hes a manager at for me. its an auto part store.
Bill, I already tried cleaning the prongs, Did'nt do anything. they were dirty and such but didnt change wen i cleaned them.
savegoodautonfg
1,085
  • Dec 8, 2006
But i could just unplug and make sure its doesnt overheat?
savegoodautonfg
1,085
  • Dec 9, 2006
hello?
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Dec 9, 2006
  • Dec 9, 2006
can you just replace the sensor?
MikeC
240
SLC, UT
Dec 9, 2006
#10
  • Dec 9, 2006
  • #10
Get one from a salvage yard. It may not work either though.
stangbear427
2,401
New England
Dec 9, 2006
#11
  • Dec 9, 2006
  • #11
I accidentally unplugged it once in my GT, the result was that the light was almost always on. Then I couldn't get the little bastard plugged in again. There must be a trick to it, I gave up.
savegoodautonfg
1,085
#12
  • Dec 9, 2006
  • #12
Yea I was wondering abou that.
I have a GT.
Does anyone else here know how to get the light to go away?
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Dec 9, 2006
#13
  • Dec 9, 2006
  • #13
Get the damn 10 dollar sensor and fix the problem!
Jughead
58
Allison Park, PA
Dec 17, 2006
#14
  • Dec 17, 2006
  • #14
Just fixed mine.
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
