low coolant light
  • Thread starter Thread starter jgfiveoh
  • Start date Start date Dec 10, 2006
1 of 2 Next Last
jgfiveoh
102
Topeka, KS
Dec 10, 2006
  • Dec 10, 2006
my instrument cluster has a low coolant light but it has never worked. there is no sensor on the overflow tank. it's a 90 5.0L lx.
was the coolant sensor an option or standard equip for my car? i thought that all 5.0's had the coolant sensor? was mine there at one time but now missing?
where is the harness for the sensor located at?
carbed87
215
  • Dec 10, 2006
im pretty sure it's part of the overflow cap, seeing as how theres wires going into it, thats always where i thought it was.
jgfiveoh
102
Topeka, KS
Dec 10, 2006
  • Dec 10, 2006
ya, its supposed to be part of the cap, but someone must've just put an el cheapo cap on there because there's no sensor or wires that i can find tucked in somewhere.
it is an E coded VIN
carbed87
215
  • Dec 10, 2006
huh, well i wouldn't be too concerned if it's not going off. just check your coolant whenever you check your oil.
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Dec 10, 2006
  • Dec 10, 2006
Only GT's came with a low coolant light. I don't know why your LX even HAS the bulb installed. I would just pull the cluster and take the bulb out.
Nick
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Dec 10, 2006
  • Dec 10, 2006
Nick
I have a low coolant light in my Stang, and it is functional.
R
Reed
78
BC, Canada
Dec 10, 2006
  • Dec 10, 2006
Same here.
jgfiveoh
102
Topeka, KS
Dec 11, 2006
  • Dec 11, 2006
i guess that's what i'm trying to figure out first is whether all 5.0's had the light or just the GT's?
TheBocSez
652
Converse, TX
Dec 11, 2006
  • Dec 11, 2006
My 91 LX has a functioning Low Coolant light and sensor......It just tends to function too often, even when full of coolant.
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Dec 11, 2006
#10
  • Dec 11, 2006
  • #10
Its a waste and it dosent work right.. Just check it regularly..
TheBocSez
652
Converse, TX
Dec 11, 2006
#11
  • Dec 11, 2006
  • #11
If you have a low coolant light and you remove the sensor, replacing it with just a regular cap; will the light stay on or off?
Adams91LX
689
12
29
Plano, TX
Dec 11, 2006
#12
  • Dec 11, 2006
  • #12
I have a low coolant light on my LX...
BDASPNY
103
HAMPTON ROADS
Dec 11, 2006
#13
  • Dec 11, 2006
  • #13
i had the same prob, cleaned it no help. just unplugged it no prob after that. just keep an eye on fluids like you should anyway.
Saleen0679
876
24
49
Yakima, WA
Dec 11, 2006
#14
  • Dec 11, 2006
  • #14
I believe it was 90+ when the LX was equipped with the low coolant light. Previously it was GT only.
Turkey Sammich
Jul 12, 2006
154
Dec 11, 2006
#15
  • Dec 11, 2006
  • #15
I concur. Even though it may be funtional, I still wouldn't trust it.
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Dec 11, 2006
#16
  • Dec 11, 2006
  • #16
On the 87-89 cars..only the GT's had the coolant lights. The LX's have the wiring to make it functional, but only the GT's came fully equipped.
On the 90+ cars, i beleive it was either standard on all 5.0's are part of some package. Either way, you could get the light on a 90+ 5.0 LX
With the plug unhooked, the light won't function. So if you don't have the sensor in the cap, all you need to do is find a cap with the sensor in it and locate the plug harness somewhere in the front driver's side harness and plug it in
jgfiveoh
102
Topeka, KS
Dec 11, 2006
#17
  • Dec 11, 2006
  • #17
thanks for all the replies. i found that i do have the harness for it. it was tucked down by the battery and i couldn't find it at first.
i also read in my owners manual that all 90 5.0's had the coolant sensor.
not sure if i'm going to use it or anything, just wanted some clarification on whether i should have it or not. i thought i had heard at one time that only GT's had it and i basically wondered what the stipulation for it was.
anyways now i and hopefully others learned something. thanks
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Dec 12, 2006
#18
  • Dec 12, 2006
  • #18
Your manual is wrong.
jgfiveoh
102
Topeka, KS
Dec 12, 2006
#19
  • Dec 12, 2006
  • #19
ok...show me otherwise
stang8urimport
Autozone Junkie
1,499
12
59
Daytona Beach, FL
Dec 13, 2006
#20
  • Dec 13, 2006
  • #20
My 90 is proof.
1 of 2 Next Last
J
Fox Lost all gauge cluster function after Holley Terminator X install (solved)
  • Justin17383
  • Nov 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 13, 2026
2000xp8
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Looking forward to collaborating with my new community
  • phil2001svt
  • Sep 24, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 10, 2026
phil2001svt
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Electrical No dash lights
  • slojoexxx
  • Dec 11, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Dec 11, 2025
slojoexxx
