Low Coolant Sensor
The sensor is in the coolant overflow tank. its also the cap for it. If you got coolant in their you may need to replace your sensor. if not. Put coolant in it and see if the light goes off
Yours might be fine if you clean it. They get crud on the prongs and then don't function properly. It only takes a few minutes to pull it and clean it.
Good luck.
