Low Oil Pressure?
GT_Rich
172
North Canton, OH
I just started driving this car, so bear with my lack of knowledge. Where does everyone's stock oil pressure gauge read at idle and at say 3k rpm? Is the gauge in our cars (92, specifically) a dummy gauge, or an actual gauge that will read a variey of pressures. I know in my old Supercouple, it was just an on/off gauge.
I ask b/c I noticed today I'm reading only one to two clicks above the "L". Are sending units common problems with the 5.0's? Or do I have a bigger problem on my hands. Motor was rebuilt (supposedly) 30k miles ago and has a B-cam. Other than that, stock and uses no oil.
Thanks,
Stock gauge can not be trusted to give an accurate reading of Oil PSI. Everyone here will tell you to get an aftermarket gauge to verify your pressures.
You'd like to see 30PSI @ 2000 RPM with warm oil
Thanks for the replies...
Is there a write-up any where for installing electric autometer gauges for oil PSI and water temp? I was actually thinking about doing the 2-pod a-pillar gauges anyways. Will the autometer gauge use the stock sending unit? Where will it tap into at? Same with the water temp?
Thanks again,
The autometer gauge will coem with it's on sending unit. You either replace your stock sender with the auotmeter or run a Tee fitting and keep both functioning. Wiring is really simple you have th ewire from the sender tot he gauge. A power wire for the gauge that can hook to a fuse such as for the blower motor. A power wire for the light in the gauge that works really well hooked to the fuse for the dimmer switch (so that the lights dim with the panel lights) and then just a ground for the gauge and a ground for the gauges light.
Oh and like everyone else said don't pay much attention to the stock gauge.
