Low oil..
AcE XBOX
144
The "Low Oil" indicator on the dash board keeps turning on. I checked the oil and it's fine. Sometimes it turns on and sometimes it turns off. Any ideas what might be wrong?
It's a 96 GT 5-speed.
Thanks
Mine does the same thing. I think in 96 they place the low oil sensor in a bad location. Everytime I park on a hill, with the nose facing downward, my light seems to kick on when I start the car.
I own a 96 GT 5-speed.
When I park 'downhill',
when I start the car, sometimes the 'low oil'
comes-stays on.
That said, keep your oil FULL.
Half a quart low, add half a quart.
R.
The switch is question is not the oil pressure switch. If you climb under your stang and look in the side of the oil pan you will see a sensor there. Make sure the connector is plugged in good and the wires going up are not bare
