Low speed fan
  • Thread starter Thread starter 94gsl5.0
  • Start date Start date May 11, 2005
94gsl5.0
223
seatown
May 11, 2005
  • May 11, 2005
When is the low speed fan supposed to turn on? I thought it was whenever the heat or defrost was on. The reason i am asking is because i just installed a V-2SQ, now my low speed fan won't switch on when i have the defrost, heat or airconditioning switched on. I did crack an air-conditioning line right at the pressure switch connector during the install. So that was unplugged and left hanging. Do i need to have that connector plugged in to have the low speed fan turn on?
I know this is the 5.0 tech forum and i have a 94, but i thought you guys might also be able to help me. I also posted in the 94-95 forum, thanks.
sgarlic
3,085
May 11, 2005
  • May 11, 2005
It should definately run with the a/c or defroster.. but not the heater. There's a plug on the compressor which controls it.. so yea you should fix it and plug it back in
HISSIN50
34
129
May 11, 2005
  • May 11, 2005
with no load (accessories) the low speed fan should come on at 208*F and the high speed should come on at ~226*F.
and what Andy said about it coming on with A/C, etc is correct. have you checked to see if the fan plug is connected? if you see a circuit breaker on the connector, it has been in for recall work in all probability.
you can check pin 14 on the CCRM to ensure you have 12 volts when the fan should be on (with A/C, etc).
also, many folks wire in fan switches for the low speed and high speed fan control. the low speed requires fused 12 volts (to pin 14) and high speed is at pin 17 and gets ground.
good luck.
94gsl5.0
223
seatown
May 12, 2005
  • May 12, 2005
I plugged the connector back in minus the ac line i cracked and still got nothing from the fan with the AC or defrost on. My high speed fan comes on when the car reaches temp but seems to be intermitent but the low speed will not engage at 208 at all. Everything was working fine before the install.... would me banging around the CCRM have anything to do with it? Is it that sensative to shock? I was grinding on the bracket with the box still attached. I guess the only way to find out is to test the wires.... its gonna be another long night after work The more i think about it the more i have a feeling its the CCRM or the fan itself.
HISSIN50
34
129
May 12, 2005
  • May 12, 2005
having a CCRM take a dump is not unusual. it is a box of relays basically.
i would grab your DMM and probe Pin 14 with the a/c set to on or the car up over 210* and see if the DMM shows 12 volts.
if it does, the ECT is telling the CCRM to turn the fan on, but there is an issue elsewhere in the wiring. that is a real quick test to help give a direction to pursue.
do make sure that all the underhood fuses and relays function too.
good luck.
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
M
cooling fan not turning on, but does when ac is on or when coolant temp is jumped or unplugged.
  • Mycarhatesme
  • Mar 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 12, 2026
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
  • dan50
  • Jul 18, 2026
dan50
