low speed surging
Blue89gt
404
Denver Colorado
I just replaced the fuel pump and fuel pump control relay on the car because the pump went out.
I did a complete tune-up on the car and filled it with fresh gas. at 2000rpm the car will surge if i let off of the gas and let the car coast in gear. lower RPM produces the same bucking.
when i am maintaining speed (slight throttle) the car surges similarily as as the coasting.
I cannot figure it out there are no codes and the car other than that runs fine.
could it be the TPS sensor?
bro my car does the same thing, i asked a couple days ago the same question. might be a page back. I was told its just normal of a 5 speed car.
Yep, reset the TPS. you may have to play with it a couple times to get it to smooth out. On mine a slight throttle the A/F would go off the scale lean and it would buck. It was worse at 200 degrees after running the interstate. I also set it hot ( a little different than cold).
Jamie
Jamie
i cleaned my EGR and IAC, adjusted the TPS, i have a new cap and rotor and all that.. and the thing still bucks if i dont ride that clutch out. :shrug: sometimes it bucks hard enought that if i had dentures i think they would hit teh dash :rlaugh: at this point i just toss it in 2nd, and it goes away :shrug:
well i took the S/C off today and will be selling it on ebay. the surging seems to be better now that I adjusted the tps.
there is a low speed skip. it sounds like it is missing on one cylinder. i just dont get it. i will be looking at the firing order in a minute. i hope that fixes the problem.
any ideas. it seems like it goes away ofter 2000rpm.
well the car actually seems to be skipping at all rpms.
I checked the timing and the firing order, its all good.
Tomorrow I'll check to see if there is spark at all of the cylinders, hopefully there is. I am starting to think it is a head gasket maybe. thier are a small amount of small bubbles in the rad. fluid.
