Low Voltage At Idle
MafiaMustang
12
I have a 1990 fox with a 3g conversion. For some reason I'm getting low voltage at idle. I can See my headlights dim. When I bring up the RPMS the lights brighten. I have a fresh battery and an upgraded 3G alternator with upgraded wiring. I do have dual electric fans on the car but can't imagine they are taking that much juice. Another issue which may or may not be related my turn signals and reverse lights are not working. I checked fuses and all looks good. My hazards are working though.
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,092
9,229
224
Massachusetts
crank, alternator pulley sizes, and idle rpm?
Pretty much. You need to be sure you are spinning the 3G alt fast enough at idle to make full charge. Usually they come with a large 3" pulley on them. This slows them down on a fox.
What is your crank and alt pulley size?
MafiaMustang
12
I have a underdrive pulleys on the car and the 3g alternator is whatever came with it. That could really cause such a fluctuation?
FastDriver
My dad had a bra
SN Certified Technician
Sep 5, 2001
4,543
1,247
214
Fort Knox, KY
FYI, Mike, that part is misidentified as a 1 7/8" pulley. It is actually 1.69". So, less than 1 3/4". I bumped the rev-limiter down to 6k to keep the alt at less than max. My normal 7k rev limit would've spun the alt to almost 19k.
Mustang5L5
Mod Dude
Feb 18, 2001
33,092
9,229
224
Massachusetts
I think they are measuring the outer lip to make that claim. I assume you measured where the belt rides?
FastDriver
My dad had a bra
Sep 5, 2001
4,543
1,247
214
Fort Knox, KY
I actually mic'ed all of it and the outer lip measures 1.94", which is how it's advertised on Summit Racing (<- click for link). I saw that pulley before I ordered it on another website, but I didn't realize that they were the same part number until afterwards.
I spoke with ASP who verified that I'd received the correct part, said they'd been advertised wrong like that for 20+ years and he didn't know why. He told me that he'd custom make me on for $75! Go figure. You order a part as advertised, pay for it, get it, it's wrong, and they want 3x more money to make the part you originally expected.
Thread starter Similar threads Forum Replies Date
Jmed05GT Low voltage while idling and no battery light 2005 - 2009 Specific Tech 1
90topdown base idle reset- low TPS voltage Fox 5.0 Mustang Tech 2
9 can bad o2 sensors cause idle surge and low maf voltage... Fox 5.0 Mustang Tech 18
YadiStang Low voltage at coil - after trying to start the motor? 1965 - 1973 Classic Mustangs -General/Talk- 1
T Fuel Low voltage at pump harness plug. 2.3L (N/A & Turbo) Tech 9
Russ Cochran Low voltage at pin connector on alternator Mustang Sound & Shine All 1
E Low voltage at fuel pump fuse SN95 V6 Mustang Tech 4
9 94 gt low voltage at fuel pump 1994 - 1995 Specific Tech 0
S Electrical Low Voltage In 87 Fox Fox 5.0 Mustang Tech 5
C Low Voltage Fox 5.0 Mustang Tech 4
B Electrical Tps Troubles. Low Voltage At The Vref Or Org/wht Wire. Fox 5.0 Mustang Tech 26
echo7 Battery Voltage Seems Low To Me... 2015+ (S550) Mustang -General/Talk 7
69shocktower Electrical Running Voltage Too Low 69 Coupe? Classic Mustang Specific Tech 3
Buko Code 66 Low Maf Voltage- All Checks Ok. Ecm? Help! Fox 5.0 Mustang Tech 4
8 help tps low voltage Fox 5.0 Mustang Tech 7
Yellow302 Low Voltage, belt slipping? What other causes? 1994 - 1995 Specific Tech 16
M DPFE voltage too low SN95 V6 Mustang Tech 1
S ECT Voltage Low Fox 5.0 Mustang Tech 2
6 Alternator low voltage Classic Mustang Specific Tech 2
5 low voltage code on maf sensor Fox 5.0 Mustang Tech 1
G low voltage problem. help!! Fox 5.0 Mustang Tech 8
G low voltage problem The Welcome Wagon 2
D Voltage Spike - Both Low and High 1994 - 1995 Specific Tech 4
itltrot TPS voltage REALLY low?? Fox 5.0 Mustang Tech 0
itltrot Tps voltage really low 2.3L (N/A & Turbo) Tech 1
Airbeast Low VREF voltages and speedometer going crazy after engine install. SN95 4.6L Mustang Tech 3
Z Will low voltage cause problems? SVT Tech Forum 10
officer dick High temp, battery light, low voltage, and it won't start with out a push. 1994 - 1995 Specific Tech 10
ninety15.0 Code 66 LOW MAF VOLTAGE Fox 5.0 Mustang Tech 4
P low voltage battery light flashing... anyone know y? SN95 4.6L Mustang Tech 2
D 3g installed...still low voltage....help!! Fox 5.0 Mustang Tech 7
STROKED_LX Low voltage Fox 5.0 Mustang Tech 2
9 Mod help, low voltage from pullies? Also intake help! Fox 5.0 Mustang Tech 8
reenmachine Check out this low-voltage warning light setup... Classic Mustang Specific Tech 1
B Low Battery Voltage Fox 5.0 Mustang Tech 5
Mr_Q 3G alt and my voltage is still low. Something else? Fox 5.0 Mustang Tech 5
flgants Will low voltage from the alt make the CHECK ENGINE light come on? 1994 - 1995 Specific Tech 1
hernandez low voltage reading Fox 5.0 Mustang Tech 4
junkstang95 High temp, high oil press, low voltage??? Fox 5.0 Mustang Tech 9
M New Electric fan :) low voltage :( Classic Mustang Specific Tech 15
E EVP voltage to low Fox 5.0 Mustang Tech 6
Scott W PULLEYS - hp increase vs low voltage? Fox 5.0 Mustang Tech 16
darryl paarman A/C idle up control- Low input or High. ? Digital Self-tuning Forum 2
B Stutter or jerk at low throttle? 2005 - 2009 Specific Tech 30
L Help with procharger low end torgue The Welcome Wagon 1
C Engine Help diagnosing a whine at low gas pedal pressures - 1998gt SN95 4.6L Mustang Tech 2
ragtop88 Electrical Low Coolant Sensor Fox 5.0 Mustang Tech 2
F What's it Worth? Red on red 1984, GT vert, 5.0, 26k miles What is it Worth?!?!? 0
M Scary front end wobble at low speed only 2005 - 2014 Specific V6 Tech 3
fredfifty Engine Low Oil Sensor Gasket Leak Fox 5.0 Mustang Tech 2
