Lower Control Arm bushing
  • Thread starter Thread starter bad68coupe
  • Start date Start date Aug 4, 2006
bad68coupe
220
Richardson, TX
Aug 4, 2006
  • Aug 4, 2006
is there any way to remove the ball joint on the lower control arms on a 68 coupe, or do they just have to be replaced? i cannot find anything that would cause them to detach and all of the new ones i see come with the ball joints attached as opposed to the UCA's where they are not.
2bav8
2,511
Mesa, AZ
Aug 4, 2006
  • Aug 4, 2006
The factory lower arms are designed to be replaced.
A few aftermarket vendors do produce lower control arms with replacable ball joints and bushings with a substancial price increase.
hungrymonkey
White by Birth, Trash By Choice
12
108
Oregon.
Aug 4, 2006
  • Aug 4, 2006
I bought a set of lca's from mustangs plus about five years ago. The ball joint could be replaced. I just bought new ones and they ball joint is welded on.
It also came non painted and had to assemble the grease fitting and boot.
they must have changed manufacturer.
As for replacing. There should be 4 bolts/rivits on the lca ball joint.
R
R4000
  • Aug 4, 2006
You can take a sharp chisel and hammer and break the existing rivets on your LCA ball joint. I believe Moog makes replacement LCA ball joints that will mount up on your existing LCAs.
Jester67
908
TN
Aug 4, 2006
  • Aug 4, 2006
They do Car Quest has them.
T
Resolved Steering won't return to centre
  • Tom77
  • Apr 28, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
Tom77
T
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
H
QA1 coilovers rubbing/hitting control arms
  • hassler
  • Sep 3, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
hassler
H
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
