Lower Control Arm bushing
bad68coupe
220
Richardson, TX
is there any way to remove the ball joint on the lower control arms on a 68 coupe, or do they just have to be replaced? i cannot find anything that would cause them to detach and all of the new ones i see come with the ball joints attached as opposed to the UCA's where they are not.
The factory lower arms are designed to be replaced.
A few aftermarket vendors do produce lower control arms with replacable ball joints and bushings with a substancial price increase.
I bought a set of lca's from mustangs plus about five years ago. The ball joint could be replaced. I just bought new ones and they ball joint is welded on.
It also came non painted and had to assemble the grease fitting and boot.:shrug:
they must have changed manufacturer.
As for replacing. There should be 4 bolts/rivits on the lca ball joint.
You can take a sharp chisel and hammer and break the existing rivets on your LCA ball joint. I believe Moog makes replacement LCA ball joints that will mount up on your existing LCAs.
