Lower Head bolts
mister5150
37
so.. im getting mixed responses. if the lower head bolts are not sealed correct will you get an internal leak meaning oil in coolant or will you get an external leak meaning puddles on the ground.....thanks
arent head bolts torqued to 60 ft lbs? water isnt getting past that. Use a moly based lube and water wont be an issue and it will ensure torque values.
i torqued the upper to 90 and the lower to 80 i used arp bolts dipped in oil however on the bottom i used teflon tape instead of the arp sealer.. im having some issues just trying to eliminate somethings
Wow, easy on the replies. This forum is for people to find out how to do things correctly, not to be judged on what they have done.
Yes the lower head botls should be sealed or an internal coolant leak can result. Teflon tape is not a rcommended sealant. ARP thread sealant is recommended or something equivalent.
thanks nero6... ive changed the gasket twice and both times it seems my oil and my coolant are mixing .. now is it to late for me to pull those lower bolts out one at a time and reseal them and torque them down?
Posted via Mobile Device
no. replace them one at a time, but use the recommended tq sequence when you tighten them back down. all will be well.
honestly though if oil and coolant are mixing you have something else going on besides lack of thread sealer on the bolts.
You already have a thread about this subject.
http://www.stangnet.com/mustang-forums/815751-2nd-head-gasket-3rd.html
Here's what you need to know:
1. No, water and oil CAN'T mix if the lower head bolts are not sealed properly.
2. Yes, the lower head bolts MUST be sealed. (moly lube is not enough)
3. No, teflon tape is NOT an acceptable sealant to use on them.
4. Most commonly used sealers: permatex or a hard setting thread sealant.
5. Yes, you can take one lower bolt out at a time and re-torque it after applying the proper thread sealant.
6. When you drain your coolant to remove and seal the head bolts, you will not be able to drain what is in the block by simply removing the lower radiator hose or opening the radiator drain... you will have to remove one of the head bolts and use a turkey baster or siphon to suck the extra coolant out of the block so the level is below the lower row of head bolts. This is to make sure the coolant doesn't keep the thread sealant from sealing.
If you have water and oil mixing, the most common reasons are:
1. Blown head gaskets (warped head or block deck)
2. Improperly sealed lower intake gaskets (gaskets can shift during installation or a warped intake)
Hope this is clear enough.
internal does not seem possible to me.
i however was just out there doing my lowers, due to external leaks
i pulled each lower bolt started on either side of the middle one and teflon pasted them with a little bit of rtv just b4 the step. mine were leaking UNDER the head to on the ground, oil looks fine. then i did the outside bolts last. i torque to 75 on the lowers , 80 on the uppers
