Lower intake install ?
BYRDPE
1,556
Memphis,Tn.
In a few days I will be installing ported GT40 heads and intake along with a cam.
1. What I need to know is what parts can I install on the lower prior to installing it on the heads?
2. Do I use any sealant on the lower intake gaskets and if so what areas?
Thanks
I generally leave everything off the lower. Bolt it on an then install the fuel rails, heater hard line and other sensors. You can bolt the t stat housing on the lower before installing it. I don't think that it would get in the way when you put it on.
As far as sealant, I use some around each of the water jacket openings and instead of the cork end gaskets I use a thick bead of black RTV at each end of the intake.
Make sure you follow the torque pattern for the intake and torque to spec. After you torque to spec you will most likely have to go back throught the bolts again in the same pattern till you get them all torqued. If you only do it once, you will find the bolts are way below the torque spec.
