madams74
The only hole other than the one for holding the intake rubber seal I know is a dummy area cast in the block like where the oil pressure switch's used to go. It serves no purpose. I use the red tacky gasket holding material for gaskets, I use RTV on the corners in 4 locations where the intake meets the heads, along with the blue rubber end pieces that come with the gasket. Do not waste your money on ARP for an intake. Serves no purpose but for cosmetics in this location. Do not buy the cheap chrome intake bolts from the local parts store for a SBF intake AKA Mr Gasket ones. They strip and break at 22 ft lbs. VERY CHEAP. Just use originals or buy some Grade 5 or 8 strength from Lowes or Home Depot. Use the white Teflon bolt sealant with the brush on all these items. It serves not only to allow for more precise toque readings, but for sealing as well. I use this stuff on everything.
