LOWER RAD HOSE
  • Thread starter Thread starter bi19tri
  • Start date Start date Sep 14, 2006
bi19tri
45
  • Sep 14, 2006
Anyone have trouble with the lower rad hose colapsing?
marine_2003
427
Lake County, FL
Sep 14, 2006
  • Sep 14, 2006
I had that problem on my 85, but it happened because I was running straight water for a long period of time.
8950HO
658
  • Sep 14, 2006
You can get lower rad hoses with a long spring inside to prevent collapsing.
My old lower Dayco rad hose I recently replaced came with a spring.
The new lower hose from the Ford dealer didn`t,so I put the spring from the old hose into the new hose.
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 14, 2006
  • Sep 14, 2006
That spring works great. Usally a callapsing hose means its worn out.
HISSIN50
34
129
Sep 14, 2006
  • Sep 14, 2006
It seems to me that it isnt too common on 5.0s (more common on Mod motors as I recall).
But as mentioned, they come/should come with springs for a reason. Post what it's doing if you want peoples' input as to other causes of the issue.
Good luck.
bi19tri
45
  • Sep 15, 2006
It6 will idle at 180 go down the road at 180 but if I get on it it will shoot up to 220-230 and not cool back down with out shuting down and waiting I had the thought about the hose yesterday The new on at advance auto parts had no spring so I got the flex hose to try
HISSIN50
34
129
Sep 15, 2006
  • Sep 15, 2006
So even if you get on it, it gets hot, then you let it idle, it wont cool back down? The hose should really only ever collapse at high RPM's.
Is the new hose rubber or metal? I've been wanting to try a metal one but they're $$.
Good luck.
bi19tri
45
  • Sep 15, 2006
Its rubber with a spring built in im thinking that once it sucks it shut it stays that way other wise it seems even when building the heat it should cool back off
HISSIN50
34
129
Sep 15, 2006
  • Sep 15, 2006
I think there are pressure equilibrium issues that allow the hose to reinflate. With no flow from a collapsed hose, pressure would build and repressurizing the hose.
The hose would collapse if the pump was sucking faster than water could make it through the coil and there was no relief to get the hose repressurized.
bi19tri
45
#10
  • Sep 15, 2006
  • #10
I am going to put some flush in it when I put it back together
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Sep 15, 2006
#11
  • Sep 15, 2006
  • #11
Sounds like you need to flush that rad. Perhaps you have a blockage issue at the bottom of the rad which is not allowing the pump to pull enough coolant and callapsing the hose.
bi19tri
45
#12
  • Sep 15, 2006
  • #12
My big question is is the rad big enough for that motor I dont want to keep chasing my tail
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
L
Engine New guy heater hose question. 85 gt 4bbl.
  • linemech31
  • Jan 17, 2026
Fox 5.0 Mustang Tech Jan 20, 2026
General karthief
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
J
Mustang 1968 coupé restoration hvac
  • JackStang68
  • Mar 3, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
zookeeper
Oil cooler delete 4v 4.6 1999 cobra mustang
  • sami12
  • Feb 24, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 25, 2026
GOvert
G
