It6 will idle at 180 go down the road at 180 but if I get on it it will shoot up to 220-230 and not cool back down with out shuting down and waiting I had the thought about the hose yesterday The new on at advance auto parts had no spring so I got the flex hose to try
Its rubber with a spring built in im thinking that once it sucks it shut it stays that way other wise it seems even when building the heat it should cool back off
I think there are pressure equilibrium issues that allow the hose to reinflate. With no flow from a collapsed hose, pressure would build and repressurizing the hose.
The hose would collapse if the pump was sucking faster than water could make it through the coil and there was no relief to get the hose repressurized.
Sounds like you need to flush that rad. Perhaps you have a blockage issue at the bottom of the rad which is not allowing the pump to pull enough coolant and callapsing the hose.
