  • 1994 - 1995 Specific Tech
Lowering a 94 gt
  • Thread starter Thread starter 8mycsh
  • Start date Start date Aug 14, 2004
8mycsh
66
Medicine Hat, Alberta
Aug 14, 2004
  • Aug 14, 2004
Just wanted to get some opions on lowering, how low should I go? I bought the 94 lowered 2 inches. But the car is lowered unevenly it seems. The passanger side is lower then the driver side by about 1/2 inch and the rear passenger side is 3/4 inch lower the rest of the car....time to replace the suspension.
Need some input from people who have lowered their cars please. Can anyone recommend a good suspension kit (springs, shocks, struts etc)
Thanks
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Aug 14, 2004
  • Aug 14, 2004
It's all a matter of 1) preference, and 2) money.
If money were no consideration, I'd get H&R race springs for the rear, MM coil-overs for the front, and Bilstein shocks & struts.
Cheaper would be to skip the coil-overs and go with H&R's on the front too.
Cheapest would be the Ford Bullitt kit, which includes C-springs and Tokico shocks/struts. Not as much lowering as other aftermarket options.
Dave
8mycsh
66
Aug 14, 2004
  • Aug 14, 2004
As far as preference I am not really sure what I want, so any recommendations are welcome.
M
mustangmatt685
144
San Diego
Aug 15, 2004
  • Aug 15, 2004
well, I love my saleen suspension, if you want to see pics of the stance it has, heres my site http://www.cardomain.com/id/mustangmatt685 Page 3 has some good pics of the stance. It handles SO well, with some nice tires and this suspension ull be lovin life. I got the full kit with bushings and shocks and struts, caster/camber plates and all, its not too low, so i can push it, but low enough where you acn tell the stance was changed. PM me if you have any questions.
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Aug 15, 2004
  • Aug 15, 2004
I just had my suspension redone over the past week. As mentioned above, I can say that this combo handles way better than stock and is fine for daily driving:
H&R Race Springs (1-1.25" drop, high spring rates)
Bilstein shocks/struts (worth every penny)
New Quad shocks (old ones had 135K miles)
Poly spring isolators (ride is now quiet)
front swaybar poly bushings
MM C/C plates (aligmnent now accurate)
MM Aluminum Steering Rack Bushings (tighter)
Rear pinion snubber (duh!)
I just got an alignment at a local shop (because it was bad before and only worse after the upgrade) and now it rides better than before. The steering is better than when new and the car simply rides straight as an arrow.
NO BUMPSTEER...........and I'm not kidding. I tested the car out on some roads I know well that are far from smooth and the car did not dart anywhere. Just soaked up each bump and kept going dead on straight. MM said this would be the case and I'm glad I didn't waste money on bumpsteer stuff for my particular setup.
That's my experience so far. Just added new 3.55 gears, speedo gear, aluminum differential, new waterpump, and replaced oil pan gasket. Now the car feels quicker, tranny feels smooth, car stays cool, and no more oil leaks! That's a lot to change at once, but OMG it was worth it.
Now I finally feel like I'm headed somewhere with my car.
Good luck.......and definitely do something!
8mycsh
66
Aug 15, 2004
  • Aug 15, 2004
I was just curious, do you guys recommend converting the rear suspension to coilover as well?
Here is the kit a local shop put together for me:
MM Front Coil-Over Kit
MM Rear Coil-Over Kit*
Pair 2-1/2' Hypercoil Springs
Pair 2-1/4' Hypercoil Springs
Bilstein Sport Front Struts
Bilstein Sport Rear Shocks
MM Caster/Camber Plates
* If you do not have an MM Panhard bar, you also have to add the rear lower shock mount.
Price $1534.02
I have parted it from what you guys have provided to me. Other then the H&R Race Springs.
baglock1
The Bartender
6,612
Space Coast, FL
Aug 15, 2004
  • Aug 15, 2004
I'm pretty happy with my setup, coilover's front and rear.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
F
For Sale 03 Redfire Cobra Convertible
  • FastFox5oh
  • Jul 14, 2026
SN95 Mustangs For Sale (1994-04) Jul 14, 2026
FastFox5oh
F
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
