Lowering Spring / Camber Plate Question
Steeda has C/C plates that are designed to be used with lowered cars. There are several spacers in the C/C plate kit for use with lowering springs
Yeh its generally a good idea to use the camber plate bc they fix the camber problem that the lowering springs cause. Another problem that lowering springs cause is bumpsteer. That can be fixed with a bumpsteer correction kit. this link tells you the problems that accure when lowering a stang. http://www.miracerros.com/mustang/t_suspension.htm.
This is the bumpsteer correction kit. http://www.mustangwarehouse.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=1&Category_Code=50L6
http://www.mustangwarehouse.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=1&Category_Code=50L11
