  • SN95 4.6L Mustang Tech
Lowering Spring Question
  • Thread starter Thread starter mineralgray2002
  • Start date Start date Dec 6, 2005
mineralgray2002
33
Centralia, Illinois
Dec 6, 2005
  • Dec 6, 2005
I have been wondering about lowering springs. i have heard that if you lower your mustang you have to buy caster/camber plates to get it all aligned right. can anyone tell me if they are needed or what all do i need to know before i consider doing it. thank you
BooWFO
991
Louisville, KY
Dec 6, 2005
  • Dec 6, 2005
Depends on how much you lower.
usually with up to 1.5" drop you don't need CC plates.
Over 1.5" you usually do Most also suggest if you lower it plan on new shocks and struts.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Dec 6, 2005
  • Dec 6, 2005
what he said if it's not a drop over 1.5" then you don't need them but an alignment is needed. Now it it is over 1.5" then you will need them to get the full adjustment
Y
Y2K4 STANG
36
NEWPORT NEWS VA
Dec 6, 2005
  • Dec 6, 2005
I just lowered my 04 vert with Steeda 1.5 sport spring and I didnt use cc plates and it alined fine.
tomustang
Psychotic Member
3,434
McLean Hospital
Dec 6, 2005
  • Dec 6, 2005
if you can afford them, do it. just get a good set
Alacrity
64
Oakton, VA
Dec 6, 2005
  • Dec 6, 2005
Is only a front wheel alignment required with the CC plates and 2 inch drop?
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Dec 6, 2005
  • Dec 6, 2005
if you do get the CC plates get the 4 bolt form MM
jeffnoel
1,638
Clovis, CA
Dec 6, 2005
  • Dec 6, 2005
You should get the front aligned after any drop.
ToplessStang
591
Montreal, Canada
Dec 6, 2005
  • Dec 6, 2005
The advantage to getting C/C plates is not just so that you can get the alignment to spec but you can actually set it to a diffent and more aggressive spec that you just can't set it to in stock form. The 4 bolt MM plates are great and they give you a revised alignment spec in the instructions.
Alacrity
64
Oakton, VA
Dec 6, 2005
#10
  • Dec 6, 2005
  • #10
I know, and my question was do I need JUST a front alignment or should I get the back aligned too for some reason?
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Dec 6, 2005
#11
  • Dec 6, 2005
  • #11
Generally, if you don't dropp more then 1.5", your not "required" per say. But i think its good idea to have them. you can tweek them more for better handring and stuff...
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Dec 6, 2005
#12
  • Dec 6, 2005
  • #12
you CANT align the rear of a solid axle car!!!!!! unless you got an IRS cobra all you can adjust is the front. i'm an alignment tech for goodyear. trust me i work with these cars everyday. if you drop it get the plates. stock plates give about 0.5 degrees adjustment. M/M plates give you at least 4 full degrees. and the caster is adjustable independantly from the camber with the M/M. they are the ONLY plate that i have or ever will put on my personal vehicle.
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
2003-04 Mustang Cobra Brake Conversion
  • Cassiebaebae
  • Oct 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 24, 2026
Bib36`
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
