Ok i was told my drivers side springs were worn and they looked like they were so i got them replaced
i bought ford racing springs which lowered my car close to a inch... so it said
my car before tilted on the drivers side and rub some... still does the same thing now with the springs only now a lil worse... car looks even but if you put your fingers on the tire and feel up to the fender well theres a noticable difference between the both sides... so my drivers side is still lower then then the other but not by much... as far as i can tell my passenger side doesnt rub at all... what is causing my car to lean on the driver side?
should i replace the shock on that side? Rack and Pinon?? what other parts could factor into this??
should i run a smaller tire.... right now i have 225 60 R16 on pony rims all the way around
thanks for any help!
