  • SN95 4.6L Mustang Tech
lowering your stang
  • Thread starter Thread starter turbokid
  • Start date Start date Aug 31, 2004
T
turbokid
113
  • Aug 31, 2004
I currently have eibach springs on my stang. the back has about a 2 inch drop and the front has a 1.5 drop. Im planning to lower the front another .5 inch. I was wondering if i have to cut my springs to lower it another .5 or can i lower it without cutting??
thanx in advance!
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Aug 31, 2004
  • Aug 31, 2004
You could try taking out the iscolater pads first before you start cutting a coil out of the front springs!! Should get another 1/4" out of her.
02mingreyGT
280
Portales, NM
Aug 31, 2004
  • Aug 31, 2004
Sounds like the best option to me but will that hurt ride quality or throw off the alignment bad?
D
dknuttgen
  • Sep 1, 2004
You could also put in the Steeda X2 ball joints. That would bring down the front a little more.
04DarkShadowGT
474
Fort Wayne, IN
Sep 1, 2004
  • Sep 1, 2004
I personally wouldnt take out the isolators as it will increase vibration, etc. However it will give you a lower stance if you do.
You could also try some of the steeda control arms with the adjustible spring perch and adjust the rear to where you want it. I know it doenst help the front but at least you have the advantage of LCA and an equal ride height.
tygr1
318
SoCal
Sep 1, 2004
  • Sep 1, 2004
Did you HAVE the springs installed, or did you do it? If someone else did it, did they orientate the springs in the proper position.
My Eibach Pros were installed at a shop...I ended up with 1-1/2" drop at the rear, but only 7/8" to 1-1/8" in the front, and they just never settled down.
I finally removed them myself and found that the lower perch has a special notch in it for the end of the last coil to DROP into...guess what...they had ther springs turned enough so that the last coil rode over the top of that notch. I DID remove the isolaters, put pieces of bicycle inner tube over all the end coils and re-installed.
Doing this got me an ADDITIONAL 3/4" drop for almost 2" in the front! I love it now!
Hope this helps.
T
turbokid
113
  • Sep 1, 2004
THANX FOR ALL THE HELP GUYS... I DID THIS AT A SHOP A WHILE BACK I MIGHT JUST TAKE IT BACK TO THE SHOP TO REDO THEM...
01GT eibach
1,075
Pittsburgh, PA
Sep 2, 2004
  • Sep 2, 2004
This is good that you are not going to do it, because there is another factor to consider here ... Pro Kit are progressive-rate springs with a different spring constant in the middle of the spring than the edges. It is a terrible idea ... generally ... to cut progressive-rate springs.
N
For Sale FOR SALE: H&R Super Sport FRONT springs only, 79-93 Mustang, 51650.77 F
  • nfilut43
  • Nov 2, 2026
  • Suspension Parts
Suspension Parts Today at 5:33 AM
nfilut43
N
H
New here and thanks
  • HoosierD420
  • Aug 30, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 30, 2026
HoosierD420
H
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
D
2006 Roush Stage 2 Mustang Chin Spoiler/Lower Grill Inserts Needed
  • DG_Damn_Good
  • Oct 13, 2026
  • The Welcome Wagon
The Welcome Wagon Oct 14, 2026
DG_Damn_Good
D
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
