I just put in the Lucas on my last oil change. 1 part Lucas to 4 parts Motocraft 10W-30. It pretty much turned my 10W-30 into 10W-40. I have an underground heated garage that never gets below 0 degrees celsius which is the freezing point of water so in that sense, it won't gum up like hell. I did it as I know the stuff "hangs" on to the cylinder walls and coats the gaskets (prevents drying) well so when the car sits idle for a couple of weeks in between starts, I know when I do a "cold" start, the oil pressure will go up faster, and the wear inside won't be as bad. I don't know about using it if I stored my car outside in cold temperatures. I think I'd use it with a 5W-30 or something like that.
I've put about 300 km on the engine or 188 miles since before the storage. The oil still looks nice and clean and I started her up just last weekend with no problems.
Come spring though, out the oil goes and I think I'm switching to the 10W-30 Valvoline high mileage oil from now on.
I've never heard a poster here complain about Lucas that it ruined their engine, and I've called a 15 year pro 5.0 racer who said he doesn't use it, but didn't think the stuff could do any real damage and has never pulled a block apart that had used it and was damaged by it, or worked on an engine where the Lucas may or was a culprit.
I saw the site about how the Lucas could interfer with the anti-foaming agents of conventional oils, however, foaming could occur once the oil gets really hot, and I noticed that on long trips (1 hour) after my oil change, the oil on the dipstick was slightly less hot than when I was just running the conventional stuff alone. Apperently, one of Lucas's bragging point's about it's oil stabalizer is it keeps the engine cooler due to better lubrication.
It couldn't hurt trying it, but I'm trying something else next time.
