m.c. push rod
  • Thread starter Thread starter mustangdave
  • Start date Start date Mar 17, 2007
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Mar 17, 2007
  • Mar 17, 2007
In a 67, was the push rod for manual drum brakes adhustable. Trying t figure out if I have the original pushrod or not. Also, what configurations, if any, did have an adjustable m.c. pushrod?
2nd Mustang
2,488
Southern California
Mar 18, 2007
  • Mar 18, 2007
I'm in the process of ordering a "new" MC this time. The "remanufactured" on lasted only four years, but on to your question. My manual for a 67 doesn't show an adjustable push rod for the manual brakes. The instructions just say to hook everything up, coat the nylon bushing on the brake pedal with 10w oil, bleed the MC and test brakes. My 67 with power discs has an adjustable pushrod.
J
Jimmys66
419
Paw Paw MI
Mar 18, 2007
  • Mar 18, 2007
Not to hi-jack..... but, I have a 66 with a late model m/c and would also like to find a source for an adjustable pushrod.
M
mustangdave
2,976
North Carolina
Mar 18, 2007
  • Mar 18, 2007
The guys that make the bilet m.c.'s (JMC?) have one but it is expensive. We should be able to source one from a parts store.
J
Jimmys66
419
Paw Paw MI
Mar 19, 2007
  • Mar 19, 2007
I can find an adjustable push rod for a power brake car that goes thru the booster, but that's it.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Mar 20, 2007
  • Mar 20, 2007
The stock part is not adjustable.
O
outlaw66
124
Flowood, Ms
Mar 20, 2007
  • Mar 20, 2007
Cobra-automotive has an adjustable pushrod. Cost is $79.95, P/N 100-A21161. Tel is 203-284-3863. Absolutely necessary if you want to get all that free play out of manual brakes. Its pricey and may be available elsewhere but this is the only one I know about. After you get over the price, the end result is a high and hard brake pedal.
Outlaw66
SoCalCruising
2,437
SoCal
Mar 20, 2007
  • Mar 20, 2007
I made one by cutting off the pushrod about 1" from the pedal end, then turning that end down just enough to thread it for 5/16". I then made a short sleeve, threaded at both ends for 5/16. One end is threaded with loctite to the pushrod and the other has an ARP 5/16" bolt screwed into it (12-point head cut off and smoothed with belt sander. Now I have an adjustable rod. After trial fitting, you can mark the rod (at ARP bolt) and loctite that end, too. Anyway, I got tired of having play and this was all available to me from stuff I had laying around.
BTW, Scott Drake has one for about $50.
J
Jimmys66
419
Paw Paw MI
Mar 20, 2007
  • Mar 20, 2007
Thank you both for the tip. Actually, I ordered a catalog from Cobra Auto. 2 weeks ago and haven't received it yet.
I did a full Cobra disk brake swap and the only thing I didn't like, other than using the factory pads, was that the brake pedal didn't start to apply decent pressure until half-way down. I can lock the brakes, but it happens with the pedal less than an inch from the floor. Makes me a little nervous.
I'm assuming Drake has a website. I'll look it up. Thanks again.
Decurion
353
Livonia, MI
Mar 20, 2007
#10
  • Mar 20, 2007
  • #10
I didnt know MC donalds made car parts...
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
D
4.6L 4 valve Sleeve
  • DangStitches
  • Oct 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
