m90 blower pulley size
Twisted306
37
i have a eaton m90 what pulleys make 6 psi :shrug: yea im going to run it on a mild 5.0 i heard a ot of people say its to small but cant beat the buck when a vortech is over $2000. kinda more a fun thing to make. so far im in this kit for under 250$ frist time runing blower not sure how to do the pulley math:bang:
Isn't that just the Thunderbird SC supercharger? If it's the stock pulley I don't think you'll see more than 4-6 psi on the stock pulley from what i've heard so you will be ok. If you can fab it I don't think you can go wrong for the price though.
Personally I would like to see a 460 w/ twin m90's on top in a fox, that would be the ultimate junkyard build to me :shrug:
*Stupid CA and smog laws can't get away with anything custom like that though for me...
i only have the blower pulley i dont have a crank pulley yes its a supercoupe blower. the 3.8 pulley dose not bolt to 5.0 crank bolt holes are diff for the 5.0 pulley
my runs the 429-460 m90 on them are to small. i was told even the 671 blower i gave him was to small for it but for street cruise it would work.................easyer way TWIN turbos:lol: :lol: hmm a 128mm turbo on a 460 thats will be a monster
What you're going to make for boost pressure is all going to depend on the amount of restriction you're seeing at the intake and exhaust side. The rule of thumb is, the more you're able to reduce the restriction on the intake side, the higher your "boost pressure" is going to be. The more you're able to open things up on the exhaust side, the lower your boost pressure is going to be. Both equal an increase in power, so don't concern yourself with boost figures so much. Moving the air in and out as efficiently as possible is what you're after. I'd start with a 3" pulley and go from there. If you want to spin it a little harder and do a pulley swap, back it with a water/methanol injection set up and let her fly! Keep in mind, these blowers will pretty much hit the wall after 16,000RPM so spinning it much beyond that is fruitless. If you're having trouble finding a crank pulley, Innovators West is the place to have a custom one made.
For the record, there are one or two guys on here with custom M90 set up and they're seeing around 370-380RWHP with pulleyed M90's and your average slew of bolt ons (mild H/C/I combinations, T/B, Exuaust, etc).
The blower kit on my 4.6L Mercury Cougar utilizes a 3rd Generation M90S (basically an S-ported version of what came on the '94-'95 Thunderbird SC) and it makes enough power for me to see 12's in my 4,000lb, automatic, IRS equipped MN12 Mercury Cougar. Pretty good considering the car in stock trim ran high-15's. :nice:
the blower has a 3" pulley wicth crank pulley do i need for 6 psi motor has gt40p heads b cam cobra intake ported and heads are ported with a 3" exhaust mac long tube headers 1"3/4
